dodS12 Posted February 25, 2013 Share Posted February 25, 2013 caute, mam dlhodobejsi problem, s tym, ze mi palubny pocitac vypisuje ABS fault spociatku sa to stavalo, az pri rychlosti nad 130 km/h pri prejdeni cez hocijaku nerovnost, mi vypisalu tuto hlasku ABS fault, potom mi to zacalo robit uz aj pri 110 km/h, no po urcitej dobe, to prestalo a mozem ist aj 170 km/h cez nerovnosti a je vsetko OK, ale teraz pri takmer kazdom nastartovani auta, mi vypise hlasku ABS fault, a potom uz nie , iba pri starte. Ale ABS mi napriek tomu funguje. Bol som kvoli tomu aj na diagnostike a diagnostika ukazala,ze ABS je v poriadku a nie je tam ziaden problem. Neviem co s tym mam robit, ako tu hlasku odstranit, je mozne ze uz su zle cidla na ABS? a preto mi pri kazdom starte vypisuje tu chybovu hlasku? Stretli ste sa uz s tymto problemom? motor mam 2,2 HDI, 2001 r.v. Quote Link to comment Share on other sites More sharing options...
Ferry Posted February 25, 2013 Share Posted February 25, 2013 vymenit spinac rucni brzdy Quote Link to comment Share on other sites More sharing options...
dodS12 Posted February 25, 2013 Author Share Posted February 25, 2013 vymenit spinac rucny brzdy? mas to odskusane? Quote Link to comment Share on other sites More sharing options...
Drobeczek92 Posted February 25, 2013 Share Posted February 25, 2013 když je v hájí spínač, tak to vypisuje BREAK FLUID LOW LEVEL né ? Quote Link to comment Share on other sites More sharing options...
dodS12 Posted February 25, 2013 Author Share Posted February 25, 2013 mne to vypisuje ABS fault Quote Link to comment Share on other sites More sharing options...
Charlie 1 Posted February 25, 2013 Share Posted February 25, 2013 ten snímač ručky mám asi 3ks:papa Quote Link to comment Share on other sites More sharing options...
dodS12 Posted February 25, 2013 Author Share Posted February 25, 2013 a kde ich najdem tie spinace? a ako zistim, ktory z nich je zly? Quote Link to comment Share on other sites More sharing options...
ladosak Posted March 3, 2013 Share Posted March 3, 2013 Mně to psalo ABS FAULT když mně praskl čtecí kroužek na homokyneťáku. Quote Link to comment Share on other sites More sharing options...
Dspee Posted March 4, 2013 Share Posted March 4, 2013 mě to same, čtecí kroužek prasklý, ta samá chyba. tím že praskl se roztáhl a mohl se šoupnout když se to stalo přišlo hlášení, pokaždý jsem to narovnal a chyba zmizela když už se to hybalo moc čas přilepil jsem to natvrdo vteřiNákem v pozici v jaký má být normálně a už se chyba neukázala. Quote Link to comment Share on other sites More sharing options...
dodS12 Posted March 4, 2013 Author Share Posted March 4, 2013 a kde najdem ten cteci krouzek homokynetaku? a akym sposobom sa to da opravit? vymenou toho kruzku? Quote Link to comment Share on other sites More sharing options...
koblih69 Posted March 4, 2013 Share Posted March 4, 2013 O kroužcích tu najdeš vše potřebné včetně odkazu kde objednat nový.... Quote Link to comment Share on other sites More sharing options...
dodS12 Posted March 4, 2013 Author Share Posted March 4, 2013 je to mozne odstranit tu hlasku bez toho aby som kupoval novy ten homokynetak? je to mozne nejak opravit? Quote Link to comment Share on other sites More sharing options...
koblih69 Posted March 4, 2013 Share Posted March 4, 2013 Když píšu objednat nový tak tím myslím ozubený kroužek za 200,-ale to bys už dávno věděl kdyby sis ty témata vyhledal. Quote Link to comment Share on other sites More sharing options...
dodS12 Posted March 4, 2013 Author Share Posted March 4, 2013 no ved preto som zalozil temu aby som vedel, ako to odstranit Quote Link to comment Share on other sites More sharing options...
koblih69 Posted March 4, 2013 Share Posted March 4, 2013 Jako že ti je mám najít Kdyby to nestačilo, můžu ti to sem třeba přepsat aby ses tím hledáním nemusel zdržovat jako já [upravil dne 4/3/13 21:06 od koblih69] Quote Link to comment Share on other sites More sharing options...
dodS12 Posted March 4, 2013 Author Share Posted March 4, 2013 potrebujem len poradit, nic ine Quote Link to comment Share on other sites More sharing options...
777-Ado-777 Posted March 6, 2013 Share Posted March 6, 2013 to dodS12: predovšetkým pozri či nieje medzi snimačom ABS (taký čierny valček) a ABS krúžkom bordel, je medzi nimi malá medzera, ja som tam mal blato a robilo to to isté. Quote Link to comment Share on other sites More sharing options...
dodS12 Posted May 10, 2015 Author Share Posted May 10, 2015 takze po dlhej dobe som zistil, ze na lavom prednom kolese mam prasknuty ABS kruzok, takze som ho dal objednat a vymenit, po vymene, mi uz konecne pocas jazdy nehlasi chybu ABS, pri rychlejsom prejazde zakrutou alebo pri vyssej rychlosti. ale aj tak mi pri nastartovani napise ABS fault, ale hned asi za sekundu sa chybova hlaska vymaze a na pristrojovke nic nesignalizuje, cim to moze este byt? moze byt ten ABS kruzok zle namontovany? Quote Link to comment Share on other sites More sharing options...
misho.1709 Posted October 13, 2016 Share Posted October 13, 2016 (edited) Vedel by mi niekto poradiť čo spraviť, ak mi pri rýchlejšom prejazde zákrut (pod plynom, ale aj bez plynu) naskočí chyba ABS? Pri pomalšom prejazde nič nenaskočí, mám to vypozorované už za niekoľko mesiacov. Po lopate povedané, naskočí vtedy, keď sa jedno koleso pretočí viac ako druhé. Diagnostika hlási prechodnú závadu: Informace o rychlosti otáčení kola. Chyba zmizne po niekoľkých naštartovaniach, no pri rovnakej situácii naskočí opäť. 406, 2.2 HDi, 2002 Edited October 13, 2016 by misho.1709 Quote Link to comment Share on other sites More sharing options...
FrantaCV Posted October 13, 2016 Share Posted October 13, 2016 Podobně se chovalo moje ABS, jen k vyvolání chybové hlášky stačila větší nerovnost na vozovce nebo třeba železniční přejezd. Dia hlásila levé zadní kolo. Chyba se během cca 1/2 roku opakovala stále častěji. Postupná výměna čidla, kroužku i kabelu od čidla problém nevyřešila. Skončilo to výměnou ŘJ ABS. Asi jsou chyby, které Dia neumí odhalit - tvrdohlavě ukazovala na snímač. To co popisuješ by právě ukazovalo na ŘJ. Nestejnoměrné otáčení kol by tuto chybu vyvolat nemělo - tedy pokud nemáš také zabudované ASR což asi u 406 - 2002 nebude. Quote Link to comment Share on other sites More sharing options...
