Pechy Posted July 21, 2005 Share Posted July 21, 2005 Ahoj kluci, chtel jsem se zeptat jestli nekdo nevi o navigaci do P605, vim ze prodavaj radia s barevnym panelem , kam se to necha nahrat, ale to nemam na mysli.. Myslim ciste obrazovku s nejakym softwarem, sla by tam navigace treba Suberba nebo Octavky? Nebo delal Peugeot neco original? Za navigaci ze 607 bych se asi nedoplatil Quote Link to comment Share on other sites More sharing options...
Fusion Posted July 21, 2005 Share Posted July 21, 2005 http://forum.aceboard.net/5364-1260-46118-0-Install-dans-photos-integration-multimedia.htm Šikovnej frantík, jen tomu nerozumím. Quote Link to comment Share on other sites More sharing options...
Pechy Posted July 21, 2005 Author Share Posted July 21, 2005 No tak to jsme dva.. Ja to chci taky.. zrejmne velka financni narocnost:/ Quote Link to comment Share on other sites More sharing options...
Pechy Posted July 21, 2005 Author Share Posted July 21, 2005 Kluci,kdo by vedel jak do toho,dejte mi prosim vedet na mail.. Quote Link to comment Share on other sites More sharing options...
-vlado- Posted July 28, 2005 Share Posted July 28, 2005 zda sa mi to alebo ten panel upravil tak ze vytiahol ten bazmek s kurenim, potom ten ram v ktorom to jeotocil o 180 stupnov, namontoval toovladanie dolu--nejdu z toho ziadne mexanicke vyvody len kable,takzenemalby to byt velky problem, A POTOM priesto pre ten dysplay v podstate tvori popolnik a radio ktore vyhodil........tot moj laicky nazor...aj ja cem takeeeeeeeeeeeeeeeeeeeee.. Quote Link to comment Share on other sites More sharing options...
rimmer Posted July 28, 2005 Share Posted July 28, 2005 no musel to cele predelat...ale nic neni nemozne... Quote Link to comment Share on other sites More sharing options...
jofo Posted July 28, 2005 Share Posted July 28, 2005 Ako som pozeral tak elektricky by to nebol az taky problem. Zistoval som ako by to slo a takyto zaver: jeden komplet PC, graficku kartu s video vystupom, maly LCD panel / da sa zohnat v GM elektronik \\ program autoroute 66 a obycajny GPS. Autoroute podporuje komunikaciu s GPS a je poriesene. Radio nepotrebujes lebo pouzivas PC na prehravanie. Sikovny programator si spravy aj a[plikaciu na riadenie klimy a ostatnych veci . Asy tak by to fachalo. Uz len to nejako pekne zabudovat a z auta nevy6lezem len na malu velku potrebu. Quote Link to comment Share on other sites More sharing options...
Dydzej Posted August 3, 2005 Share Posted August 3, 2005 A neni daleko lacinejsi a univerzalnejsi koupit PDA s GPS (mozna i externi antenu) a adapter do zapalovace a vyrobit si nejakej drzacek? Jedine minus je mozna absence hlasove navigace. Quote Link to comment Share on other sites More sharing options...
jofo Posted August 7, 2005 Share Posted August 7, 2005 Jednoduchsie je ale odpada ti moznost to pouzivat na multimedia ako muzika filmy atd. Istotne ten kto potrebuje na jazdu GPS tak si pomoze aj inac. Quote Link to comment Share on other sites More sharing options...
Péťa Posted August 7, 2005 Share Posted August 7, 2005 No to je teda sila :D Borec si presunul pul obyvaku do kufru auta Zkus koupit nejaky starsi notebook s 12\" displayem a mas to vse pokupe. Quote Link to comment Share on other sites More sharing options...
Spec Posted August 7, 2005 Share Posted August 7, 2005 Až na to, že ten frantík má ten display dotykovej. Takže stačí PC a tenhle dotykovej dysplay a je to. PDA stačí taky - to umí všechno (i filmy), ale zase to nebude vypdat profi a zabudovaně. Takže jde spíš o parádu, protože když někdo potřebuje fakt jen tu navigaci, tak stačí PDA do ruky s GPS. Quote Link to comment Share on other sites More sharing options...
Péťa Posted August 7, 2005 Share Posted August 7, 2005 Původně zaslal: Spec Až na to, že ten frantík má ten display dotykovej. Takže stačí PC a tenhle dotykovej dysplay a je to. Aha, tak podrobne jsem to nestudoval... Quote Link to comment Share on other sites More sharing options...
Spec Posted August 7, 2005 Share Posted August 7, 2005 Já moc taky ne..jen jsem tam někde viděl jak to ovládá prstem na displayi přímo... Quote Link to comment Share on other sites More sharing options...
Xander Cage Posted August 7, 2005 Share Posted August 7, 2005 Kdybyste někdo chtěl, tak já mám v palubovce zakomponovaný 7\" monitor, a k tomu už by se ta navidace dala připojit. Foto klidně pošlu, sem to dát neumím.... Quote Link to comment Share on other sites More sharing options...
Dydzej Posted August 7, 2005 Share Posted August 7, 2005 Původně zaslal: Dydzej A neni daleko lacinejsi a univerzalnejsi koupit PDA s GPS (mozna i externi antenu) a adapter do zapalovace a vyrobit si nejakej drzacek? Jedine minus je mozna absence hlasove navigace. Doplneni - tak napr. sada Perfect Passenger ma i ten hlasovy vystup. Je fakt ze to uchyceni je nutne nejak zbastlit, ale kdyz jsou lidi schopny ukrast autoradio, tak bych PDA ani nijak viditelne nezabudovaval a radeji to vzdycky odendaval Quote Link to comment Share on other sites More sharing options...
Péťa Posted August 7, 2005 Share Posted August 7, 2005 Původně zaslal: Xander Cage Foto klidně pošlu, sem to dát neumím.... Pošli to na peugeot@rouskovi.com a já to sem vystavím... Quote Link to comment Share on other sites More sharing options...
Dydzej Posted August 7, 2005 Share Posted August 7, 2005 Původně zaslal: Fusion http://forum.aceboard.net/5364-1260-46118-0-Install-dans-photos-integration-multimedia.htm Šikovnej frantík, jen tomu nerozumím. Pise tam, ze dal do kufru micro-ATXovej pocitac s Athlonem 2500+ (Barton na 1.83GHz) a diskem 60GB a integrovanou zvukovkou (+dalsi specifikace) a ze si udelal power on/off na spinaci skrinku, atd. Taky ze si udelal lepsi audio (+specifikace). Az na tu desnou cervenou to nevypada spatne, asi to neni az tak drahe, takove miniITX s procesorem VIA EPIA + GPS modul by na navigaci asi stacilo, kdyz tak o tom premyslim... Misto HDD mit USB flashdisk s Win98se a aplikacema... No strilim od boku, ale zkusim se nad tim zamyslet [upravil dne 7/8/05 Dydzej] Quote Link to comment Share on other sites More sharing options...
Péťa Posted August 8, 2005 Share Posted August 8, 2005 Původně zaslal: Xander Cage Kdybyste někdo chtěl, tak já mám v palubovce zakomponovaný 7\" monitor, a k tomu už by se ta navidace dala připojit. Foto klidně pošlu, sem to dát neumím.... http://rouskovi.com/peugeot-club/P605_display.jpg Quote Link to comment Share on other sites More sharing options...
Dydzej Posted August 8, 2005 Share Posted August 8, 2005 Uz jsem nasel site, ktery prodava vsechny potrebne komponenty na stavbu carputeru (jak tomu rikaj). A 8\" TSK znamena osmipalcovy touch screen kit na osmipalcovy CD panel. Quote Link to comment Share on other sites More sharing options...
Fusion Posted August 8, 2005 Share Posted August 8, 2005 Proč je to tlačítko na stahování levýho předního okna takový divný? To má automatický stahování? Pokud jo, když ho někde seženu tak mě to bude taky dělat? A dívám se, že nejsem jedinej komu chybí šoupátko na otvírání průduchy Quote Link to comment Share on other sites More sharing options...
