LugoBoss Posted March 5, 2013 Share Posted March 5, 2013 Zdravím, mám problém se saharou nikdy se nesepne ani když odpojim hnědej konektor, relátka na sahařa cvakaj,kontakty sem prošel a nikde nic aj bitron,306 1,8 74kw 1995 s klimou ta taktéž nefunguje.Díky:papa Quote Link to comment Share on other sites More sharing options...
Ferry Posted March 5, 2013 Share Posted March 5, 2013 a tu ridici jednotku - bitron, jsi zkousel jak ? Quote Link to comment Share on other sites More sharing options...
LugoBoss Posted March 5, 2013 Author Share Posted March 5, 2013 Když sem ju odpojil a zapojil tak to cvaklo u sahary a jeste kdesi Quote Link to comment Share on other sites More sharing options...
miroja Posted March 6, 2013 Share Posted March 6, 2013 Ak cvakaju vstky relatka ako maju, tak skontroluj poistky a motory. PS: malo hladas a citas, sahary su snad najcastejsia tema v 306-kach.... Quote Link to comment Share on other sites More sharing options...
Lubo181 Posted March 6, 2013 Share Posted March 6, 2013 Pisem to kazdemu ale overeny recept prerob to na termospinac pokial mas otvor na chadici na to a ked nie tak to sprav na spinac a kontroluj si teplotu Quote Link to comment Share on other sites More sharing options...
miroja Posted March 6, 2013 Share Posted March 6, 2013 Pri jeho zavade by mu nepomohlo ani hafo spinacov v chladici alebo kabine. Navyse, ma klimu (aj ked momentalne nefunkcnu)! Quote Link to comment Share on other sites More sharing options...
Lubo181 Posted March 6, 2013 Share Posted March 6, 2013 ani me nefunguje klimatizacia ale ked napojis ventilator napriamo od baterky cez poistkovu skrinku vytvoris vlastnu poistku a rozopnes to bud termospinacom alebo spinacom tak to musi fungovat. Ja uz som menil predtym cidla relatka a neviem co vsetko a vzdy mi to robilo problemy strelil mi kamienok do ventilatora ostal seknuty ta zhorelo bitron a vsetko okolo toho a poistka ne dajaky magor tam dal 50 A. Tak som to poriesil takto a mam pokoj druhy Peugeot TD uz bol takto porieseny ked som ho kupil predosli majitel to tiez tak riesil Quote Link to comment Share on other sites More sharing options...
miroja Posted March 7, 2013 Share Posted March 7, 2013 On pise v prvom prispevku, ze Bitron relatka ovlada, kedze cvakaju, takze problem bude bud v motoroch,poistkach,alebo kabelazi. Preto si myslim, ze by mu ani tvoj \"downgrade\" auta nepomohol. Quote Link to comment Share on other sites More sharing options...
LugoBoss Posted March 7, 2013 Author Share Posted March 7, 2013 Motor funguje zkousel sem ho napojit pres baterku Quote Link to comment Share on other sites More sharing options...
P607Olda Posted March 7, 2013 Share Posted March 7, 2013 Psal jsem ti kontakt na Nečase. Doma budeš dlouho laborovat s nevalným výsledkem. Doplnění ručního spínače nepovažuji za opravu - \"auto bylo napadeno kutilem\". U Nečase to budeš mít opravené za chvilku a pan Martin ti vysvětlí funkci Bitronu (pokud tam je???) a čidel. Quote Link to comment Share on other sites More sharing options...
LugoBoss Posted March 7, 2013 Author Share Posted March 7, 2013 Jj bitron tam mám, no nejspíš to hodím do servisu a uvidím.Díky za rady. Quote Link to comment Share on other sites More sharing options...
LORD_mapiv Posted March 7, 2013 Share Posted March 7, 2013 Omlouvam se, ze lezu takhle do ciziho tematu. Mam obdobny problem a mam dotaz jestli se da jeste z nejakych motorizaci pouzit bitron a sahary na 1.9Td? Quote Link to comment Share on other sites More sharing options...
miroja Posted March 8, 2013 Share Posted March 8, 2013 Z pofaceliftovych 306-tiek nemaju BITRON motory DW10, DW8B. Ostane by mali mat BITRON ak maju klimu. Podla mna by si nemal mat problem pouzit aj z ineho modelu, mozno aj z 206,406-koveho modelu, ale to je len moj nazor. Quote Link to comment Share on other sites More sharing options...
