Jarino24 Posted February 20, 2013 Share Posted February 20, 2013 viete mi niekto poradit s tymto problemom?Na tachometri mi ukazuje realne kilometre ale na displeji mi ukazuje viac km ako je skutocne potom mi samozrejme ukazuje aj zlu spotrebu ci dojazd Quote Link to comment Share on other sites More sharing options...
ChouLu Posted February 20, 2013 Share Posted February 20, 2013 Jak velký je tam rozdíl? A jak jsi si jistý, že tachometr ukazuje dobře? Quote Link to comment Share on other sites More sharing options...
shark734 Posted February 20, 2013 Share Posted February 20, 2013 mas iny rozmer pneu ako je v TP, resp. nemas v RJ ABS/ESP nastaveny spravny rozmer kolies... aj ked su pneu v TP tak sa moze priemer kolesa lisit, treba to prehodit cez dia Quote Link to comment Share on other sites More sharing options...
Y2K Posted February 20, 2013 Share Posted February 20, 2013 povedz ten rozdiel, budeme mudrejsi Quote Link to comment Share on other sites More sharing options...
Jarino24 Posted February 20, 2013 Author Share Posted February 20, 2013 ukazovolo to rovnako ale raz po diagnostike to zacalo ukazovat inak cize sa to da nejako nastavit? Quote Link to comment Share on other sites More sharing options...
Jarino24 Posted February 21, 2013 Author Share Posted February 21, 2013 rozdiel medzi tachometrom a displejom je cca 10% Quote Link to comment Share on other sites More sharing options...
Y2K Posted February 21, 2013 Share Posted February 21, 2013 tak to v diag potrebujes zrejme nastavit spravny rozmer pneu Quote Link to comment Share on other sites More sharing options...
Jarino24 Posted February 21, 2013 Author Share Posted February 21, 2013 uvidime ale idem menit displej tak to bude treba asi vsetko nanovo sparovat cez dia,tak to dam kuknut ci je to zle nastavene Quote Link to comment Share on other sites More sharing options...
jofo Posted February 21, 2013 Share Posted February 21, 2013 Na dia sa da nastavit rozdiel +/-3km v hodine, co ma ukazovat tempomat a co realne ukazuje na budikoch. Potom uz iba ak su zle nastavene pneu. A inac ,uz si auto nastartoval? Quote Link to comment Share on other sites More sharing options...
Jarino24 Posted February 21, 2013 Author Share Posted February 21, 2013 este nie ale zajtra zhodim zospodu kryt aby som sa dostal ku starteru a uvidime ak to bude nieco ine ako cievka alebo kontakt na kably tak ma istotne drbne a este ako naschval tu nadrbalo snehu tak super :-) Quote Link to comment Share on other sites More sharing options...
P607Olda Posted February 22, 2013 Share Posted February 22, 2013 Měl jsem vyzkoušené, že \"displej\" po vypnutí motoru nuluje (zapomene) stovky metrů, tedy necelé kilometry za desetinnou čárkou. Takže když jezdíš krátké trasy, tak odchylka narůstá. Když to budeš stopovat (ověřovat) na dlouhé trase bez vypnutí motoru, tak to sedí. Je fakt, že takové drobnosti francouzi neřeší, snad bohužel, ale možná proto jsou francouzská auta jiná, než německá. 5008 už tímto netrpí, displeje ukazují shodně. [upravil dne 22.2.2013 09:58 od P607Olda] Quote Link to comment Share on other sites More sharing options...
Jarino24 Posted February 22, 2013 Author Share Posted February 22, 2013 neviem mne ukazuje dobre aj na kratke trasy ale ocovi robili nieco cez diagnostiku a odvtedy mu to ukazuje zle Quote Link to comment Share on other sites More sharing options...
P607Olda Posted February 22, 2013 Share Posted February 22, 2013 Asi mu tam změnili na míle. Quote Link to comment Share on other sites More sharing options...
