lubovrato Posted January 27, 2011 Share Posted January 27, 2011 Chystam sa na vymenu oleja a filtrov a neviem ci sa pri kazdej vymene oleja meni aj palivovy filter? Ako casto ho menite pri kazdej vymene alebo pri kazdej druhej? Quote Link to comment Share on other sites More sharing options...
DanculD Posted January 27, 2011 Share Posted January 27, 2011 Ja menim pri kazdej vymene oleja. Stoji par korun lebo sa meni iba vlozka. Neviem ako je to na 1.6HDi. Quote Link to comment Share on other sites More sharing options...
lubovrato Posted January 27, 2011 Author Share Posted January 27, 2011 Pri palivovom filtry sa meni len vlozka? Nemyslel si nahodou olejovy filter? To viem, ten menim aj ja pri kazdej vymene oleja. Niekto mi tusim spominal, ze palivovy sa nemeni casto. Ja som ho menil len pri 120 000 km a pred tym meneny asi nebol. Teraz ma caka vymena oleja pri 160 000 a neviem ci ho dat tiez vymenit. Quote Link to comment Share on other sites More sharing options...
MilanF1 Posted January 27, 2011 Share Posted January 27, 2011 palivový ve stodvacíti .... ten musel vypadat od toho parafínu. Já ho měním při oleji, tedy každých dvacet. Quote Link to comment Share on other sites More sharing options...
marko306 Posted January 27, 2011 Share Posted January 27, 2011 mením pri každej výmene oleja u mňa to vychádza po 15 000 km Quote Link to comment Share on other sites More sharing options...
br76 Posted January 27, 2011 Share Posted January 27, 2011 mal by sa podla serv.intervalu menit kazdych 90tis. ale zalezi aku naftu tankujes....ta vlozka ozaj stoji par eur...takze castejsia vymena len prospeje. Ja zajtra idem menit ale cely aj s obalom takze som zvedavy kolko to bude stat??? menil niekto uz cely filter? Quote Link to comment Share on other sites More sharing options...
shark734 Posted January 27, 2011 Share Posted January 27, 2011 na 1.6HDi je palivovy trochu drahsi(40-70€ zalezi kde kupujes), tam sa vlozka vymenit neda...nedavno som menil pri 70tkm a skusil som ho rozrezat..to nebol filter ale blato...a este v servisnej knizke bola vymena pri 50tkm pisana [upravil dne 27/1/11 10:06 shark734] Quote Link to comment Share on other sites More sharing options...
br76 Posted January 27, 2011 Share Posted January 27, 2011 ano presne tak ja mam 2,0 66KW niesu tak nachylne na znecistenu naftu ako 1,6...Takze preto je serv.interval kratsi...kolko stoji kompletny???? mne volali z peugeootu vraj 106eur... Quote Link to comment Share on other sites More sharing options...
shark734 Posted January 27, 2011 Share Posted January 27, 2011 naco to chces menit cele? ak nieje poskodeny tak je to zbytocne Quote Link to comment Share on other sites More sharing options...
br76 Posted January 27, 2011 Share Posted January 27, 2011 chcel som menit len tu vlozku ale ozaj len malo mi pusta ten filter vraj sa to pretesnit neda takze cele treba menit.... no co uz! Quote Link to comment Share on other sites More sharing options...
lubovrato Posted January 27, 2011 Author Share Posted January 27, 2011 Tak da sa pri 1,6 HDI vymenit len vlozka v palivovom filtry alebo neda? br76 pise ze nie a ostatní ano, takze? Inak nikde na nete som nenasiel, ze sa da kupit samostatna vlozka do palivoveho filtra. Alebo posle niekto nejaky link kde sa to da? Quote Link to comment Share on other sites More sharing options...
shark734 Posted January 27, 2011 Share Posted January 27, 2011 na 1.6HDi sa vlozka vymenit neda na 100% takto vyzera: [upravil dne 27/1/11 11:22 shark734] Quote Link to comment Share on other sites More sharing options...
shark734 Posted January 27, 2011 Share Posted January 27, 2011 chcel som menit len tu vlozku ale ozaj len malo mi pusta ten filter vraj sa to pretesnit neda takze cele treba menit.... no co uz! kde ti to tece? lebo ak pod vickom tak spolu s vlozkou do filtra sa predava aj tesnenie Quote Link to comment Share on other sites More sharing options...
lubovrato Posted January 27, 2011 Author Share Posted January 27, 2011 - Presne toto som nasiel aj ja, ze palivovy filter sa n 1,6 HDI menit neda. - takze na 1,6 HDI sa ma menit cely palivovy filter kazdych cca 20 000 km?? Inak na olejposta ceny palivovych filtrov pre 1,6 HDI su taketo. Palivový filter Delphi HDF939 - 42,46 € (1 279,10 Sk) Fiaam FP 5751 - 29,78 € (897,20 Sk) Hengst H219WK - 41,76 € (1 258,10 Sk) Knecht KL 431 - 39,54 € (1 191,20 Sk) Mecafilter ELG 5297 - 56,23 € (1 694,00 Sk) [upravil dne 27/1/11 11:45 lubovrato] [upravil dne 27/1/11 11:45 lubovrato] [upravil dne 27/1/11 11:46 lubovrato] Quote Link to comment Share on other sites More sharing options...
shark734 Posted January 27, 2011 Share Posted January 27, 2011 myslim ze servisny interval je 120tkm co si myslim ze je prehnane, ale zase menit palivak kazdych 20tkm je najako moc casto...olej menit po 15tkm a palivak kazdu 2-3vymenu oleja..zalezi kde tankujes Quote Link to comment Share on other sites More sharing options...
lubovrato Posted January 27, 2011 Author Share Posted January 27, 2011 No super, tuto strucnu jasnu informaciu som potreboval. Diky:-) Ked som kupil peugeota tak uz mal najazdenych 104 000 km. Takze ja som menil prvykrat olej pri 120 000 km a odrazu aj vsetky filtre, cize aj palivovy. Pred tym bol pravidelne servisovany podla servisnej knihy kazdych 20 000 km. Ja menim olej kazdych cca. 15 000 km. Minulu vymenu pri 140 000 km som palivovy nemenil. Tak teraz mam 155 000 km tak skusim palivak este nevymenit a pri dalsej uz ano. A to ze zalezi ze ke tankujem, hmmm kde mat istotu ze je to vzdy OK? Slovnaft ma sklamal ten uz obchadzam a posledne dva roky tankujem na SR len na OMW a ked v CR tak len BENZINA. [upravil dne 27/1/11 11:59 lubovrato] Quote Link to comment Share on other sites More sharing options...
MilanF1 Posted January 27, 2011 Share Posted January 27, 2011 Vzhledem k tomu, že já měním jenom vložku a tolik nestojí, tak ho měnil při oleji. Navíc ta řepka v naftě určitě nepomůže. Když ho budeš měnit po 50 000 km, tak by taky problém být neměl. Hlavně netankovat patoky typu ONO atd. Quote Link to comment Share on other sites More sharing options...
matulo Posted January 27, 2011 Share Posted January 27, 2011 no ja mam 2.0HDi 100kw a menil som cely palivovy filter, stal ma 40€ a servisak povedal, ze ho treba menit pri kazdych 60 000tis. km, takze ja doverujem jeho slovam. A inak sa s takym filtrom do peugeotu stretol prvykrat aj on aj predavac v obchode zaujimeve... Quote Link to comment Share on other sites More sharing options...
shark734 Posted January 28, 2011 Share Posted January 28, 2011 pri tvojej motorizacii sa meni tiez len papierova vlozka... Quote Link to comment Share on other sites More sharing options...
Přema Posted January 28, 2011 Share Posted January 28, 2011 no ja mam 2.0HDi 100kw a menil som cely palivovy filter, stal ma 40€ a servisak povedal, ze ho treba menit pri kazdych 60 000tis. km, takze ja doverujem jeho slovam. A inak sa s takym filtrom do peugeotu stretol prvykrat aj on aj predavac v obchode zaujimeve... To tě někdo dobře natáhl.....stačí jen vložka za cca 600,- Kč , celý filtr se mění u HDI motorů jen u 1,6 Quote Link to comment Share on other sites More sharing options...
