Kosta1 Posted October 25, 2006 Share Posted October 25, 2006 Behem posledniho tydne se mi nejak zvetsily vibrace motoru na volnobeh. evite cim by to mohlo byt? JInak otacky stabilni, kdyz trosku pridam, zmizi to. Nejakej silentblok? Quote Link to comment Share on other sites More sharing options...
Martinsk Posted October 25, 2006 Share Posted October 25, 2006 Áno mohol by to byť silentblok. Quote Link to comment Share on other sites More sharing options...
Kosta1 Posted October 26, 2006 Author Share Posted October 26, 2006 Da se to nejak odhalit, kouknout na nej? Je tam jen jeden? Quote Link to comment Share on other sites More sharing options...
Martinsk Posted October 26, 2006 Share Posted October 26, 2006 Mali by tam byť 3 alebo 4. Ževraj sa dajú nejako presvietiť. Mne to robili v servise. Quote Link to comment Share on other sites More sharing options...
Kosta1 Posted October 27, 2006 Author Share Posted October 27, 2006 Aha, tak to pri pristi navsteve zkusim nadhodit. Diky. Quote Link to comment Share on other sites More sharing options...
michal 206 Posted October 30, 2006 Share Posted October 30, 2006 jsou tam na mnoho mnoho porcent tri a pokud je to takhle jak pises, bude to nejspis \"ten uprostred vzadu\" za moterem, pristupny odspodu. Quote Link to comment Share on other sites More sharing options...
FrenkV Posted October 25, 2007 Share Posted October 25, 2007 Ahoj tak čím to prosím bylo? Dělá mi to taky dík Quote Link to comment Share on other sites More sharing options...
HOFA Posted October 26, 2007 Share Posted October 26, 2007 To by mě chlapi taky zajímalo,v poslední době při volnoběhu jsou vibrace docela znatelný,jen mám obavy aby nešlo o nějakou zásadnější závadu než jsou silenbloky,třeba aby se ty vibrace neodvíjely právě od poškozeného setrváku. Quote Link to comment Share on other sites More sharing options...
dizzi Posted November 15, 2007 Share Posted November 15, 2007 No tie vibracie mam aj ja a neviem od coho.Dost to pocut aj pri jemnom brzdeni..... Quote Link to comment Share on other sites More sharing options...
FrenkV Posted November 16, 2007 Share Posted November 16, 2007 Původně zaslal: HOFA To by mě chlapi taky zajímalo,v poslední době při volnoběhu jsou vibrace docela znatelný,jen mám obavy aby nešlo o nějakou zásadnější závadu než jsou silenbloky,třeba aby se ty vibrace neodvíjely právě od poškozeného setrváku. jj ten setrvák je docela asi reálnej,při zdechnutí motoru mi zabouchá Quote Link to comment Share on other sites More sharing options...
richardsw Posted November 17, 2007 Share Posted November 17, 2007 Ahoj, spozoroval som to iste a vcera som bol v servise a nasli nieco ine. Vyzera to na zlu trysku, auto potom funguje len na tri valce.Akurat idem znova do servisu, napisem neskor. Quote Link to comment Share on other sites More sharing options...
amiandrew Posted November 17, 2007 Share Posted November 17, 2007 Původně zaslal: richardsw Ahoj, spozoroval som to iste a vcera som bol v servise a nasli nieco ine. Vyzera to na zlu trysku, auto potom funguje len na tri valce.Akurat idem znova do servisu, napisem neskor. Myslel jsem si, že vadná tryska znamená opravdu tak velký problém, že řj. rozsvítí STOP a ty už dál nejedeš. Nebo snad HDi zvládne "jet" na tři válce? Quote Link to comment Share on other sites More sharing options...
richardsw Posted November 17, 2007 Share Posted November 17, 2007 Tak som doma, naozaj je to zla tryska, treba ju vymenit,preto som mal tie vybracie pri chode naprazno. Quote Link to comment Share on other sites More sharing options...
dizzi Posted November 19, 2007 Share Posted November 19, 2007 hmm tak a kolko ta bude stat ta tryska?Pod tou tryskou myslis vsterkovac? Quote Link to comment Share on other sites More sharing options...
dizzi Posted November 19, 2007 Share Posted November 19, 2007 hmm? Quote Link to comment Share on other sites More sharing options...
richardsw Posted November 20, 2007 Share Posted November 20, 2007 Ano vstrkovacia tryska.Ked mi dali dolu ten plast, na ktoom je napisane 1,6 HDI, nasli zanesene miesto pri jednej tryske.Original v peugeote mi povedali cenu okolo 18,000. Quote Link to comment Share on other sites More sharing options...
mbleho Posted November 20, 2007 Share Posted November 20, 2007 mal som ten isty problem...vymenene....a super kludne a tiche...ziadne vybracie..... su tam tri silentbloky..... 1.jeden uchytenie motora na nasniku silenblok je sucastou hlinikovej konzoly 2. uchytenie prevodovky...obdoba 3. uchtenie motoru zospody na napravnici...zvycajne byva v hajzly ten.....stoji par korun, takze ziadne tisicove sumy....len problemova vymena....ja som to rozobral....s nozom vyrezal ten stary a obvodny kruzok vypilil platkom z pilky....pekne ide vybrat..novy som dal do mraznicky a miesto kam ho budem davat nahria teplovzdusnou pistolou...uplne postaci..... ale este pred tym to treba prebehnut brusnym paierom a poriadne vycistit...- to je zaklad.... takto som to robil bez akejkolvek velkej demontaze ostatnych veci... jednoduchsie je vylisovat na lise...ale je to pracen a vela rozoberania....cez ten obal v ktorom je ulezeny silenblok ide aj polooos od praveho kolesa ,,cize by sa mmuselo vsetko zozoberat a to by bolo velmi pracne...a este aj ten pristu p k hornym srobom je na hovno....tokto je to jednoduchsie a pohoda...svaty...pokoj..... Quote Link to comment Share on other sites More sharing options...
dizzi Posted November 20, 2007 Share Posted November 20, 2007 tie ceny ND v peugeote su neskutocne... Quote Link to comment Share on other sites More sharing options...
dizzi Posted November 20, 2007 Share Posted November 20, 2007 mne dnes v peugeote v KE na tie vybracie a chvenenie motora povedali,ze vsetko je v poriadku-nic s tym nemam robit.Vraj im to robi aj na ich firemnom aute a je to OK.Smiesne...Nempoza niekto v KE normalneho cloveka ktory rozumie peugeotom??Mne to v servise pripada ako u blaznov.... Quote Link to comment Share on other sites More sharing options...
mbleho Posted November 21, 2007 Share Posted November 21, 2007 Původně zaslal: dizzi mne dnes v peugeote v KE na tie vybracie a chvenenie motora povedali,ze vsetko je v poriadku-nic s tym nemam robit.Vraj im to robi aj na ich firemnom aute a je to OK.Smiesne...Nempoza niekto v KE normalneho cloveka ktory rozumie peugeotom??Mne to v servise pripada ako u blaznov.... Peugeot v KE je cistz odpad.......svokor ma neskutocne zle spomienky na tento servis so svojim Terracanom...... Quote Link to comment Share on other sites More sharing options...
