MyP106 Posted May 26, 2012 Share Posted May 26, 2012 zdravim vas, mam problem s otackama. Pri vyrazeni klesnou a auto chcipne. Otacky klesaji rovnomerne ne ze by treba houpali a pak to padlo. Nevite cim to muze byt? Quote Link to comment Share on other sites More sharing options...
FiFa_cze Posted May 26, 2012 Share Posted May 26, 2012 Špatná váha vzduchu? Quote Link to comment Share on other sites More sharing options...
MyP106 Posted May 26, 2012 Author Share Posted May 26, 2012 nevim proc ale myslim ze ji tam nemam a nedelalo to 300km klid a ted. Quote Link to comment Share on other sites More sharing options...
Zbynek19 Posted May 26, 2012 Share Posted May 26, 2012 no heled ja mam ted podobnej problem...a je mozny ze to delá krokovej moturek.,.. Quote Link to comment Share on other sites More sharing options...
FiFa_cze Posted May 26, 2012 Share Posted May 26, 2012 Jo tak s tim ti moc neporadím. Kdyby to byl fichtl, tak bych ti poradil vyčistit volnoběžnou trysku ale takhle netuším Quote Link to comment Share on other sites More sharing options...
MyP106 Posted May 26, 2012 Author Share Posted May 26, 2012 to me taky napadlo nebo snimac na prevodovce. Quote Link to comment Share on other sites More sharing options...
FiFa_cze Posted May 26, 2012 Share Posted May 26, 2012 Tak vyzkůšaj a podej výsledek Quote Link to comment Share on other sites More sharing options...
ozzy56 Posted May 26, 2012 Share Posted May 26, 2012 Špatná váha vzduchu? to benzín má? Quote Link to comment Share on other sites More sharing options...
FiFa_cze Posted May 26, 2012 Share Posted May 26, 2012 Sem jenom střelil Ale každopádně to má málo benzínu při volnoběhu Quote Link to comment Share on other sites More sharing options...
Raweon Posted May 26, 2012 Share Posted May 26, 2012 106ka nema vahu vzduchu ma tzv. map senzor umysteny za skrtici klapkou jestlise nemyllim:) Quote Link to comment Share on other sites More sharing options...
FiFa_cze Posted May 26, 2012 Share Posted May 26, 2012 Joo přesně to jsem myslel, ale nevěděl jsem, jak se to jmenuje Díky Quote Link to comment Share on other sites More sharing options...
MyP106 Posted May 28, 2012 Author Share Posted May 28, 2012 Nemohl by to být třeba senzor na setrvačníku? Quote Link to comment Share on other sites More sharing options...
loki Posted May 28, 2012 Share Posted May 28, 2012 klidné to můze byt tím,zkus ho vyndat a vycistit. a není to senzor setrváku,ale čidlo otáček klikové hřídele:) Quote Link to comment Share on other sites More sharing options...
MyP106 Posted May 28, 2012 Author Share Posted May 28, 2012 já myslel že to čidlo otáček je na motoru přímo tohle je jako na obalo převodovky za šroubama. Quote Link to comment Share on other sites More sharing options...
vlk406 Posted May 29, 2012 Share Posted May 29, 2012 takže pán má nový sání a nevešel se tam regulátor volnoběhu ? bez signálu z toho čidla bys to asi nenatočil Quote Link to comment Share on other sites More sharing options...
MyP106 Posted May 30, 2012 Author Share Posted May 30, 2012 http://www.peugeot-club.com/forum/files.php?pid=1422642&aid=101101 když se podíváte na tuhle fotku tak to co já myslím je to vedle svodu na fotce v pravo pod chlazením oleje. je t ona zlomu motoru a převodovky. může to na to mít vliv? Quote Link to comment Share on other sites More sharing options...
JimBeem Posted May 30, 2012 Share Posted May 30, 2012 No to je snímač otáček - pokud je špatný tak nenastartuješ. Nicméně co sem tak pročítal fora ohledně filcek a favoritů - když ho měli zasfiněný a vyčistili ho, tak sem jim uklidnil motor, ale to se jednalo o BMM - takže 1,0i a 1,1i u peugeotu. Ale když na něj mrkneš a vyčistíš ho tak nic nepokazíš Quote Link to comment Share on other sites More sharing options...
MyP106 Posted May 30, 2012 Author Share Posted May 30, 2012 dám na vaše rady. Quote Link to comment Share on other sites More sharing options...
MyP106 Posted May 30, 2012 Author Share Posted May 30, 2012 tak pánové sháním konektor k tomuhle snímači http://cat.apm.cz/vyrobek_obrazky.aspx?apm_id=2176677 mám ho totálně rozškvařenej Quote Link to comment Share on other sites More sharing options...
loki Posted May 31, 2012 Share Posted May 31, 2012 Ahoj,a proč si ten konektor nekoupíš novej v Peugeotu Quote Link to comment Share on other sites More sharing options...
