Odesláno (upraveno)
  • TYP VNITŘNÍHO VYBAVENÍ/OBLOŽENÍ
  • LÁTKA PARSIFAL + KŮŽE CLAUDIA "RZ"
  • ALARM
  • ELEKTRICKÁ ÚPRAVA ALARMU
  • ZAPALOVAČ CIGARET
  • PŘEDNÍ+ZADNÍ ZAPALOVAČ CIGARET
  • ZADNÍ BEZPEČNOSTNÍ PÁS
  • BEZP PÁSY ZAD 3 NAVÍJEČE 3-DVEŘ
  • PŘEDNÍ BEZPEČNOSTNÍ PÁS
  • PÁS S PŘEDPÍNAČEM SE SIGNALIZACÍ
  • PODNEBÍ (VNĚJŠÍ TEPLOTA)
  • ZEMĚ NORMÁLNÍM PODNEBÍM
  • RYCHLOSTNÍ STUPNICE
  • STUPNICE V KM/H
  • STRANA ŘIDIČE (MÍSTO ŘIDIČE)
  • ŘÍZENÍ VLEVO
  • SDRUŽENÝ PŘÍSTROJ (CHARAKTERISTIKY)
  • STUPNICE DO 250 KM/H NEBO 150 M/H POZADÍ SVĚTLÉ
  • UKOTVENÍ DĚTSKÝCH SEDAČEK
  • BEZ UKOTVENÍ DĚTSKÝCH SEDAČEK ISO VZADU VPRAVO
  • REPRODUKTOR
  • 4 REPRO VPŘEDU (2 TW + 2 REP) + 4 REPRO VZADU
  • STÍNĚNÍ (ROLETKA, BOČNÍ SLUNEČNÍ CLONA, CLONA STŘEŠNÍHO OKNA)
  • BEZ ZAD ROLET
  • NASTAVENÍ VÝŠKY PŘEDNÍHO SEDADLA SPOLUJEZDCE
  • ZDVIH ZAŘÍZENÍ SPOL PODÉL SEŘÍZENÍ+PŘED
  • OVLÁDÁNÍ PŘEDNÍHO SEDADLA ŘIDIČE
  • OVL PŘED ELEKTRICKÉHO SEDADLA ŘIDIČE
  • OVLÁDÁNÍ PŘEDNÍHO SEDADLA SPOLUJEZDCE
  • OVL PŘED ELEK SEDADLA SPOLUJEZDCE
  • KOMPAKTNÍ DISK
  • BEZ MONTÁŽE KOMPAKTNÍHO DISKU
  • NAVIGAČNÍ SYSTÉM
  • BEZ NAVIGAČNÍHO SYSTÉMU
  • ŽÁROVKY DO SVĚTLOMETŮ
  • VÝBOJKA
  • SPOUŠTĚČ ZADNÍHO OKNA
  • ELEKTRICKÉ SEKVENČNÍ OVLÁD OKEN VZADU + ZAMYKÁNÍ
  • DISPLEJ
  • DISPLEJ (RÁDIO+HODINY, TEPL.,CD)
  • VYHŘÍVACÍ VLOŽKA
  • NEVYHŘÍVANÉ SED
  • PŘEDNÍ BOČNÍ AIRBAG
  • BOČNÍ NAF VAKY HRUDNÍKOVÉ VPŘEDU+VZADU + HLAVOVÉ
  • AIRBAG SPOLUJEZDCE
  • NAFUKOVACÍ VAK NA STRANĚ SPOLUJEZDCE
  • NEUTRALIZACE AIRBAGU
  • MANUÁLNÍ NEUTRALIZACE VAKU AIRBAGU
  • SVĚTLOMET S KOREKTOREM VÝŠKY
  • AUTOM SEŘÍZENÍ SVĚTLOMETŮ
  • ROZHLASOVÝ PŘIJÍMAČ
  • AUDIOSYSTÉM S PŘEHRÁV KOMPAKT DISKŮ A RDS "RD4"
  • CHLAZENÍ KLIMATIZACE
  • AUTOMATICKÁ KLIMATIZACE
  • TEMPOMAT (REGULÁTOR RYCHLOSTI)
  • REGULATEUR ET LIMITATEUR VITESSE
  • VNITŘNÍ ZPĚTNÉ ZRCÁTKO
  • VNITŘNÍ ZPĚT ZRCÁTKO DEN - NOC BEZ AUTOMAT CLONY
  • VNĚJŠÍ ZPĚTNÉ ZRCÁTKO (ZAKŘIVENÉ NA STRANĚ ŘIDIČE)
  • ASFÉRICKÉ SKLO VNĚJŠÍHO ZPĚTNÉHO ZRCÁTKA U ŘIDIČE
  • DETEKCE PŘEKÁŽKY
  • RADAROVÝ DETEKTOR PŘEKÁŽKY VPŘEDU I VZADU
  • BOČNÍ ROLETKY
  • BEZ BOČNÍCH ROLET
  • UKAZATEL POKLESU TLAKU V PNEUMATIKÁCH
  • INDIKÁTOR ZTRÁTY TLAKU PNEUMATIK
  • PŘEDNÍ OPĚRKA HLAVY (FUNKCE)
  • PŘED ELEKTRICKÁ OPĚRKA HLAVY
  • VRCHNÍ KOBEREC
  • S PODLADOVOU PODL KRYTINOU
  • ZESILOVAČ – EKVALIZÉR
  • BEZ ZESILOVAČE S EQUAL
  • OKNO (TYP)
  • ČS+ZAD BOČ VÍCEVRS ODS KROMĚ SINGAPOUR
  • VOLANT
  • VOLANT PERFOROVANÁ KŮŽE 4 RAMENA
  • VENTILÁTOR
  • 2 VENTILÁTORY 1 RYCHLOST 150 W AERO
  • PAKET VARIABILNOST / ERGONOMIE PŘEDNÍHO SEDADLA
  • BEZ PAKETU VARIABILITA ERGONOMIE PŘEDNÍHO SEDADLA
Upraveno uživatelem Agrafik
Díky. Chci se zeptat když si koupím sedadla z vyhříváním tak jestli mi tam půjdou zapojit a budou mi vyhřívat a když koupím kabeláž do předních řidičových dveří v které jsou kabely i na  ukládání řidičova sedadla do paměti a zapojím ji tak jestli mi to bude fungovat. A jestli budu muset eště něco aktivovat v řídící jednotce? Děkuji
Odesláno (upraveno)
Jo a mám eště jeden dotaz. Mám tam tlačítko na nastavení podvozku tam kde je ruční brzda ale to tlačítko mi nereaguje. Když je zmáčknu tak se mi na něm nerozsvítí to malý světýlko a ani na přístrojové desce se mi nic neukáže žádná chyba a ani auto nevykazuje žádný problém jen prostě nemůžu zapnout režim sport. Není to taky nějaký zádrhel tak jak s tím alarmem?
Jo a psal si že v té své výbavě nemám cd changer což je pravda ale známý ho doma našel a dal mi jej a byl jsem překvapen když jsem našel v kufru konektor na zapojení.
Tak mám eště dotaz zda mají ty 607 z výroby vyvedeny všechny možný konektory na vyšší výbavy?
Dík
Upraveno uživatelem tomanino42
Po stisknutí tlačítka tlumičů se ti na displeji mezi budíkama zobrazí překřížené tlumiče a ztuhne ti řízení. V případě poruchy by dioda na tlačítku měla bikat?
Máš rádio RD4 - zvládá měnič CD?
Ohledně kabeláže pochybuju, že by se vyplatilo dělat různé svazky.
Obecně by bylo dobré to dát na diagnostiku.
Tam se právě nic neobjeví a ani na tlačítku nic nebliká.
Rádio RD4 mám a na měnič jsem měl vzadu konektor tak jsem ho tam zapojil jenom to musím nechat zapnout na diagnostice.
Odesláno (upraveno)
Mám eště dotaz. Koupil jsem si originál zadní reprapráky do zadního plata ty který tam montovali JBL a chci se zeptat jak je tam připojím a jestli musím koupit zesilovač ten JBL když ho tam podle VIN nemám? dík
