Bamatala Posted July 11, 2010 Share Posted July 11, 2010 Ahojte, dnes som nastartoval auto na kupku a pustil klimu naplno a asi po 3 min. auto zdochlo Nastartoval som opäť bez problémov a isiel asi 20km bez problémov. Zastavím na semafóre a opäť zdochol. Naštartoval som ho motor beží O.K a prídem na parkovisko a zistím že pri určitých otáčkach ako keby nedostával benzín..teda držím plyn na 3000ot a zrazu spadnú a opäť vyletia, ak nepodržím plyn zdochne. ... dik za každú radu, mne to pripadá ako keby benzín nedostával...inač PC neukazuje žiadnu poruchu. [upravil dne 11/7/10 Bamatala] [upravil dne 18/7/10 Bamatala] Quote Link to comment Share on other sites More sharing options...
vendelinek Posted July 11, 2010 Share Posted July 11, 2010 Zkus si přepsat ten název,nebo ti to admini smažou Quote Link to comment Share on other sites More sharing options...
georgegg Posted July 11, 2010 Share Posted July 11, 2010 já měl podobnej problém a příčina byla vypadlej konektor z map senzoru Quote Link to comment Share on other sites More sharing options...
Bamatala Posted July 11, 2010 Author Share Posted July 11, 2010 ahha.. sorry a kde ho najdem, fakt si ma dostal MAP.. skrtiaca klapka? Quote Link to comment Share on other sites More sharing options...
Bamatala Posted July 11, 2010 Author Share Posted July 11, 2010 jj, uz viem idem pozrieť, či je O.K. diki moc [upravil dne 11/7/10 Bamatala] Quote Link to comment Share on other sites More sharing options...
Bamatala Posted July 11, 2010 Author Share Posted July 11, 2010 inač, ak by bol ten MAP fuč ukaže mi chybovu hlasku PC?, a ešte voľačo ma napadllo... od včera sa mi vidí na voľnobeh taký nervózny chod motora.Pri bežnej jazde O.K len teraz to chcipanie. Quote Link to comment Share on other sites More sharing options...
Bamatala Posted July 11, 2010 Author Share Posted July 11, 2010 konektor je O.K dik za každú radu. Quote Link to comment Share on other sites More sharing options...
eler.cz Posted July 16, 2010 Share Posted July 16, 2010 Mám trošku podobný problém. Mě tohle dělá při rozjezdu(je jedno jestli za studena nebo zahřátý) tak má motor jakoby \"pauzu\" i když přidávám plyn otáčky jsou pořád nízko nebo padají a pak to rychle vystřelý na 2500ot. - 3000ot. No a pokud stojím v koloně a pocukávám(při vypnuté klim., rádia...) nebo stojím na křižovatce a chci se rozjet, otáčky pomaličku padají až motor chcípne. Na volnoběh to běží v pohodě, většinou to chcípá až při rozjezdu Bamatala: Sorry, že jsem to hodil sem. Přišlo mě zbytečný vytvářet novou diskuzi Quote Link to comment Share on other sites More sharing options...
Bamatala Posted July 16, 2010 Author Share Posted July 16, 2010 tak som sa do toho včera pustil a zistil: myslel som si že je to krokový motorček ale ee keď mi to zdochne tak nemám vôbec tlak v paliv. potrubí, teda skúšal som to na rampe na tom odvzdušňováku a pumpa v nádrži akoby ťahala naprázdno. Pri naštartovaní tlak O.K až kým nezdochne podobne ako eler-ovi a keď je down tak tlak nie je. Na diag všetko O.K. - takže mi príde že jedine čerpadlo v nádrži. Už bol s ním trabble ale vtedy mi diag. hlásila nízky tlak paliva a na čerpadle bola prelomená hadička. Dal som tam druhú z Felicie a neviem či sa niečo nepoj... Zajtra sa do toho pustím, rozoberiem a dám info. Podľa môjho názoru sú to uhlíky na čerpadle ešte niečo. - presne tak isto nám dom zdochýnala Skoda 1203 ked sa zohriala AC pumpa :D:D [upravil dne 16/7/10 Bamatala] [upravil dne 16/7/10 Bamatala] Quote Link to comment Share on other sites More sharing options...
omegascream Posted July 16, 2010 Share Posted July 16, 2010 chalani, niečo podobné trápi aj mňa. Už som to to písal v sekcii Servis aj som s tým bol v reálnom servise a nikto nič Mne auto zatiaľ ešte nechcípne, ale podobne ako elerovi mi (za studena) ledva zvyšuje otáčky aj keď pridávam plyn a po prekročení cca 1800 - 2000 to zrazu trhne a vyrazí. Napadli ma dve veci, ale v servise to proste nechceli skúšať (nechápem prečo) a to - snímač teploty motora. Či nedáva RJ blbú informáciu a tá dávkuje zlú zmes alebo potom presne to palivové čerpadlo. Aj keď v tom prípade neviem prečo to po zohriatí motora prestane (aspoň u mňa) Quote Link to comment Share on other sites More sharing options...
Bamatala Posted July 16, 2010 Author Share Posted July 16, 2010 ... peugeot je zázrak, ale super vozenie a aj tak každé auto sa kazí Poriešime aj tento trabble neboj.. zajtra rano idem mrk na čerpadlo dam vedieť. Quote Link to comment Share on other sites More sharing options...
eler.cz Posted July 16, 2010 Share Posted July 16, 2010 Tak uvidíme. Dejte vědět hoši Quote Link to comment Share on other sites More sharing options...
Existujuci Posted July 16, 2010 Share Posted July 16, 2010 Mne motor zhasne ked jazdim v meste po ulickach a podradim z 3 na 2.Vsetko zhasne,budiky padnu dolu,aj klima sa vypne. Stava sa mi to ale len raz za 2-3 mesiace.Po nastartovani idem dalej bez problemov. Quote Link to comment Share on other sites More sharing options...
hudy Posted July 17, 2010 Share Posted July 17, 2010 Asi bych zacal tim, ze se vycisti skrtici klapka. To ze mi to zhasinalo na krizovatkach a otacky litaly sem a tam, me delala prave zanesena klapka. Quote Link to comment Share on other sites More sharing options...
Bamatala Posted July 18, 2010 Author Share Posted July 18, 2010 ... hoši ja mám problém vyriešený..ťuk, ťuk, ťuk. včera som bol na dielni u kamošša, vybrali sme čerpadlo - vyzeralo O.K. Je v ňom malý filter ten bol tiež O.K. ...hmm a čo teraz. Kamoš zobral telefón a volal do Intercars že koľko by stálo nové čerpadlo a tam mu vraví kolik, že jedno Bosch má dokonca skladom, že si niekto objednal a nedošiel. cena pre mňa 130€ , tak som mu povedal nech poň skočí. Vymenili sme ho natahali benzín a čuduj sa svete - včera som spravil 200km, nezdochol už ani raz, motor sa akoby skľudnil... proste som spokojný, veď kto by nebol za toľko € ... ešte k tej klapke - tú som čistil ako 1-vú a nepomohlo. toď môj postreh. Quote Link to comment Share on other sites More sharing options...
omegascream Posted July 18, 2010 Share Posted July 18, 2010 gratulujem a závidím Počkám, či sa to začne zhoršovať prípadne ináč prejavovať a budem mať aspoň nejaké vodítko. Ináč bol si s tým na diag.? Chcel by som totiž vedieť či by to ukázala alebo nie Quote Link to comment Share on other sites More sharing options...
Bamatala Posted July 18, 2010 Author Share Posted July 18, 2010 dik... veď práve diag. mi nič neukázala ani prechodné ani trvalé závady. Potom už zostával len pokus omyl... ja som začal vyčistením klapky - žiadny rozdiel, no a začalo sa to potom zhoršovať. !!! dnes prší tak som si spravil domáci test !!! dal som čerpadlo do vedierka a pustil na 12V nech ide v kuse a popri tom si varím...vedierko je na balkóne - teda bolo a vrčalo si. Iba zrazu počujem kolísanie otáčok čerpadla a prestalo tlačiť vodu len bzučalo. Odpojil som 12V - zapojil späť a znovu tlačí --- na neuverenie, to isté mi robilo v aute.Bude to asi motorčekom pravdepodobne uhlíky alebo nejaká zrada. držím palce pri odstranované trabble - Peugeot je super vozenie Quote Link to comment Share on other sites More sharing options...
m3t4L_m4n Posted October 24, 2010 Share Posted October 24, 2010 Ja riešim momentalne podobný ak nie ten istý problém.. Ráno keď je teraz tak chladnejšie mi auto pri zosliapnuti plynu zacne zdochynat.. Udrzi si nejakych 500 ot. nezdochne len sa dusi a ked pustim plyn nabehne pekne spat volnobeh na 1000 ot. Ked sa motor trochu zohreje problem sa uplne odstrani. Sledujem to asi týždeň predtým som sa z ničím takým nestretol ani minulý rok keď klesli teploty na -15.. Uvítam každú radu.. Do Peugeotu s tým nechcem ísť lebo ma zoderú z kože a problém aj tak neodstránia.. Skúsim nabudúce auto so studeným motorom pichnúť na diagnostiku a uvidím aké tlaky bude mať.. Možno budem múdrejší Quote Link to comment Share on other sites More sharing options...
Ladislao Posted August 20, 2013 Share Posted August 20, 2013 Jak to dopadlo , mám to samé ? Quote Link to comment Share on other sites More sharing options...
P607Olda Posted August 20, 2013 Share Posted August 20, 2013 Ladislao: m3t4L_m4n tady byl naposled 16.7. (podle profilu), tak nečekej okamžitou odpověď. U Tebe to může být taky plynem. Popiš podrobně Tvůj problém. Quote Link to comment Share on other sites More sharing options...
