sejk 0 Posted January 8 Share Posted January 8 Zdravim, chybovy kod P1458 - zavada elmag.ventilu chlad.kapaliny Peugeot 807.Dokazal se toho nekdo zbavit? diky Ondra Quote Link to post Share on other sites
ChouLu 1,442 Posted January 8 Share Posted January 8 Klasická závada u dvoulitru neřešit, nemá řešení a ničemu to nevadí Quote Link to post Share on other sites
sejk 0 Posted January 11 Author Share Posted January 11 Dekuji moc za odpoved, akorat je blbe, ze se kontrolka obcas rozsviti a pak po case zase zhasne. A porad dokola. Nyni to chci prodat a je mi to blbe, kdyz se tohle deje,ale zaroven uz do toho nechci investovat Quote Link to post Share on other sites
ChouLu 1,442 Posted January 11 Share Posted January 11 To nebude kvůli této chybě Je nutné má origo diag se podívat do deníku co kontrolku rozsvici Quote Link to post Share on other sites
sejk 0 Posted January 11 Author Share Posted January 11 Diky, k teto chybe jeste byla zavada - signal diferencialniho tlaku ve vyfukovem potrubi...souvisi to spolu? Jsem lajk,vubec netusim Quote Link to post Share on other sites
ChouLu 1,442 Posted January 11 Share Posted January 11 Ano, to už ti kontrolku rozsvítí Quote Link to post Share on other sites
sejk 0 Posted January 11 Author Share Posted January 11 A co to presne znamena? zavady sly vymazat a momentalne nic nesvitidiky Quote Link to post Share on other sites
inoxing 488 Posted January 11 Share Posted January 11 To je snímač na kontrolu FAPu (může už být skoro ucpaný, může to být jen elektronická závad- kabel/snímač) Quote Link to post Share on other sites
sejk 0 Posted January 11 Author Share Posted January 11 To je mi zahada..loni jsem filtr nechal vycistitach jo Quote Link to post Share on other sites
inoxing 488 Posted January 11 Share Posted January 11 Je tam více variant, jak jsem psal. Může to být i špatný čidlo/kabel. Dolívals Eolys po vyčištění FAPu? Quote Link to post Share on other sites
sejk 0 Posted January 11 Author Share Posted January 11 to nevim, mel jsem to v servisu a ale dolivani nic nerikali.. Quote Link to post Share on other sites
inoxing 488 Posted January 11 Share Posted January 11 No, to musíš zkontrolovat a doplnit nebo tím zase ucpeš FAP. To je aditivum- Eolys, které tam je právě kvůli FAPu a umožňuje správné vypalování. Quote Link to post Share on other sites
