shark734 Odesláno 8. červenec 2010 Odesláno 8. červenec 2010 nazdar..poprosil by som ta o servisnu historiu...VIN: VF33CRHSB82629140 Diky
Martinsk Odesláno 10. červenec 2010 Odesláno 10. červenec 2010 Původně zaslal: shark734 nazdar..poprosil by som ta o servisnu historiu...VIN: VF33CRHSB82629140 Diky Predané vo Francúzsku 11.9.2002 D.OPR PDV Opravár Číslo Zložky Kód príčiny Názov Kód priradenia Počet kilometrov Krajina 05/06/2009 186989N01 X93LJGI01 00001628ZT ELECTROVANNE 800 21026 FR 22/08/2005 186989N01 X3UB72801 00000532P9 DOUBLE VOLANT 3Q1 53326 FR 18/01/2005 186997H05 X1HK85801 000000000008997 PRET DE VEHICULE FCM 46083 FR 18/01/2005 186997H05 X1HK85802 00000139QP MOT ES DIE FCM 46083 FR 18/01/2005 186997H05 X1HK85803 00001705LV TUYAU PRECATA TR PSA K210 FCM 46083 FR 18/01/2005 186997H05 X1HK85804 0000621651 LAMPE FCM 46083 FR 30/12/2004 389013G07 X0ZC38701 000000000008999 PRESTATAIRE FRAIS INTERNES FCM 43400 FR 30/12/2004 389013G07 X1HR24901 000000000008962 DEPANN BATTERIE FCM 45515 FR 13/12/2004 186997H05 X0TP80901 000000000008997 PRET DE VEHICULE FCM 44506 FR 13/12/2004 186997H05 X0TP80902 0000032622 JOINTPALIE FCM 44506 FR 13/12/2004 186997H05 X0TP80903 0000621651 LAMPE FCM 44506 FR 16/10/2004 389013G07 X0CJ60601 000000000008999 PRESTATAIRE FRAIS INTERNES FCM 100 FR 16/10/2004 389013G07 X0CJ60701 000000000008950 REMORQUAGE FCM 100 FR 07/09/2004 186997H05 XZKD11801 00008149VV RETROVISEUR EXT G 000 41856 FR 07/09/2004 186997H05 XZNN19701 0000000000000XF CONTROLE GEOMETRIE 000 41856 FR 07/09/2004 186997H05 XZNN19702 0000032627 JOINT 000 41856 FR 20/08/2004 186997H05 XZCE18201 0000000000000AH CLIMATISEUR FCM 40507 FR 20/08/2004 186997H05 XZCE18202 0000000000000SE REVISION 40000 FCM 40507 FR 20/08/2004 186997H05 XZCE18203 00004246W8 KIT2DISQUE FCM 40507 FR 20/08/2004 186997H05 XZCE18204 0000637211 LAMPE FCM 40507 FR 20/08/2004 186997H05 XZCE18205 00006426KY JEU BALAIS FCM 40507 FR 15/04/2004 186997H05 XXLI94401 0000000000000BB GARNITURE DE TOIT 000 32777 FR 05/03/2004 186997H05 XWWR55101 0000000000000MY TRAIN AVANT BARRE ANTI-DEVERS AVANT 000 31749 FR 05/03/2004 186997H05 XWWR55102 0000000000000YB INJ ELECTRONIQUE MOT DIESEL (L C D) 000 31749 FR 05/03/2004 186997H05 XWWR55103 00006236F2 AVERTISSEUR 000 31749 FR 18/12/2003 186997H05 XVUW84501 00006426KY JEU BALAIS FCM 29168 FR 07/08/2003 186997H05 XUAE30901 0000000000000SC REVISION 20000 FCM 20800 FR 17/06/2003 186997H05 XTKW17001 0000000000000XE ECHANGE D\'EPROM (PIECE FOURNIE) 000 16230 FR 16/12/2002 186997H05 XRHK10401 000000000008997 PRET DE VEHICULE E24 9012 FR 16/12/2002 186997H05 XRHK10402 0000000000000NA SUSPENSION ARRIERE 000 9012 FR 20/11/2002 186997H05 XRAK84001 0000000000000EN SERRURE DE PORTE 000 4760 FR 20/11/2002 186997H05 XRAK84002 00005206W0 AMORTISSAR 000 4760 FR
shark734 Odesláno 10. červenec 2010 Odesláno 10. červenec 2010 ahoj...este by som ta poprosil dalsie VF33C9HZC83578826 vdaka
alihen Odesláno 11. červenec 2010 Odesláno 11. červenec 2010 cavte chcem vas poprosit o zistenie historie P 307 Break pre kamarata VIN: VF33ERHYB83398828 dakujem
Martinsk Odesláno 13. červenec 2010 Odesláno 13. červenec 2010 Původně zaslal: shark734 ahoj...este by som ta poprosil dalsie VF33C9HZC83578826 vdaka Predané v Taliansku 14.5.2004 D.OPR PDV Opravár Číslo Zložky Kód príčiny Názov Kód priradenia Počet kilometrov Krajina 22/01/2007 117420301 3CVIGNY01 00006451YZ COMMANDE EXT 57500 IT 22/11/2006 117420301 3CUA94401 0000225752 CONTACTEUR FEUX EXT 53200 IT 22/11/2006 117420301 3CUA94402 0000621546 PORTE-LAMPE PY21W EXT 53200 IT 22/11/2006 117420301 3CUA94403 00006563W0 AFFICHEUR EXT 53200 IT 17/10/2006 117420301 3CTC73101 0000000000000NL ALIMENTATION D\'AIR EXT 52090 IT 17/10/2006 117420301 3CTC73102 0000000000000XH DEPOSE POSE AUTORADIO EXT 52090 IT 17/10/2006 117420301 3CTC73103 00000382AZ RACCORD AIR EXT 52090 IT 17/10/2006 117420301 3CTC73104 00000532Q3 DOUBLE VOLANT EXT 52090 IT 12/05/2006 117420301 3CNX88201 00000532P9 DOUBLE VOLANT 000 37602 IT 12/05/2006 117420301 3CNX88202 0000621546 PORTE-LAMPE PY21W 000 37602 IT 22/07/2005 117420301 3CFB36901 0000000000000NJ CANALISATION ALIMENTATION INJECTEUR X6Y 21840 IT 08/07/2005 117420301 3CFE90601 0000000000000BT BOITIER SERVITUDE INTELLIGENT 000 20200 IT 08/07/2005 117420301 3CFE90602 00004246W8 KIT2DISQUE 000 20200 IT 13/08/2004 117420301 3BRB29001 0000000000000MV ROUE AR G/D X5M 5821 IT
Haemorrhage Odesláno 15. červenec 2010 Odesláno 15. červenec 2010 Ahoj, můžu poprosit o VF33C9HXC85006952? Děkuji
Kenedi Odesláno 16. červenec 2010 Odesláno 16. červenec 2010 Zdravim, chcel by som sa opytat na historiu VIN: VF33H9HZC84561123 Dakujem
Martinsk Odesláno 16. červenec 2010 Odesláno 16. červenec 2010 Původně zaslal: Kenedi Zdravim, chcel by som sa opytat na historiu VIN: VF33H9HZC84561123 Dakujem Predané v Belgicku 14.2.2006 D.OPR PDV Opravár Číslo Zložky Kód príčiny Názov Kód priradenia Počet kilometrov Krajina 28/12/2007 045931F X91DDYZ01 0000621698 LAMPE PROJECT H1 12V-55W 000 92101 FR
Kenedi Odesláno 16. červenec 2010 Odesláno 16. červenec 2010 dakujem takze ziadne ine dalsie vady ktore by ohrozovali kupu tam niesu? bol som ho dnes pozriet a ze nejde klima lebo sa zvykne pri transporte vyprazdnit. co je na tom pravdy a ake mozu byt vady?
Kenedi Odesláno 16. červenec 2010 Odesláno 16. červenec 2010 a ten pocet kilometrov je evidovany pri tej poslednej oprave alebo k akemu datumu je to aktualne?
Martinsk Odesláno 17. červenec 2010 Odesláno 17. červenec 2010 To bolo 28.12.2007 a stav tachometra bol 92101 km. A ako sa môže vyprázdniť klíma pri transporte. To je dobrá hovadina. Koľko má to auto teraz kilometrov na tachometri. Lebo mne vychádza, že má 200 - 220 000 km.
Kenedi Odesláno 17. červenec 2010 Odesláno 17. červenec 2010 no auto ma na tachometri 97000km servisna knizka ze je k tomu tiez.. len tu nevedel hned najst. takze.
Kenedi Odesláno 17. červenec 2010 Odesláno 17. červenec 2010 a to pri transporte s tou klimou.. to ze vraj belgicania zvyknu vyprazdnovat klimy pred transportom .. tak isto ako sa odpaja baterka aby sa nieco nestalo. tak neviem pozri toto: http://peugeot-307-sw.autobazar.eu/16-hdi-comfort-pack-plus-id1705781.html
Kenedi Odesláno 17. červenec 2010 Odesláno 17. červenec 2010 Mozes mi prosim este povedat nieco o tomto aute: VF33H9HYB84356305 Dakujem
Martinsk Odesláno 18. červenec 2010 Odesláno 18. červenec 2010 Původně zaslal: Kenedi Mozes mi prosim este povedat nieco o tomto aute: VF33H9HYB84356305 Dakujem Predané vo Francúzsku 28.9.2005 D.OPR PDV Opravár Číslo Zložky Kód príčiny Názov Kód priradenia Počet kilometrov Krajina 23/10/2006 180311G01 X9EB61901 0000000000000CB BOUCLIER AVANT 000 54361 FR 21/06/2006 180311G01 X7RZ04201 000000000001612 TELECHARGEMENT CONTRÔLE MOTEUR YAW 40995 FR 12/05/2006 186314G03 X7IU85301 0000000000000MJ RESERVOIR A CARBURANT REMPLISSAGE 000 36508 FR 12/04/2006 180311G01 X6UX69401 000000000001204 TELECHARGEMENT B S I YAH 30769 FR
Martinsk Odesláno 18. červenec 2010 Odesláno 18. červenec 2010 Původně zaslal: Kenedi no auto ma na tachometri 97000km servisna knizka ze je k tomu tiez.. len tu nevedel hned najst. takze. Tak, že auto je stočené ...
Kenedi Odesláno 19. červenec 2010 Odesláno 19. červenec 2010 Mozes prosim este toto auto: VF33H9HYB84312667 Dakujem velmi pekne.
Balci Odesláno 19. červenec 2010 Odesláno 19. červenec 2010 Dobry den. Taky bych velmi pekne prosil. VF33CNFUC83246241 Dekuji moc...
fernet soda Odesláno 19. červenec 2010 Odesláno 19. červenec 2010 Ahoj všetkým pežoťákom prosím akekolvek udaje o mojom peugeotiku VF36E9HZC21424035 Veľmi ďakujem ďakujem ďakujem!!!!! [upravil dne 19/7/10 fernet soda]
Milhaus65 Odesláno 19. červenec 2010 Odesláno 19. červenec 2010 Původně zaslal: fernet soda Ahoj všetkým pežoťákom prosím akekolvek udaje o mojom peugeotiku VF36E9HZC21424035 Veľmi ďakujem ďakujem ďakujem!!!!! [upravil dne 19/7/10 fernet soda] Země prodeje : FR Odpovědná země : SK Datum zač. záruky : 20/01/2006 21/07/2006 147112Z X8EJ08901 0000621622 LAMPE PROJECT 000 36981 km FR
