VojtouNerCZ Odesláno 23. květen 2020 Autor Odesláno 23. květen 2020 (upraveno) It looks like your latest FW fixed all the problems Awesome work. Now I just need to figure out why the screen goes OFF after I plug your PSAWifiDisplayControl Both EPS are still turned on, but the screen will go black. Maybe some fault at my side (some short circuit or something else) So after some investigations, I builded second board and still same problem. No short circuit, everything connected as on schematic. So I tried to play with wires and find out, that GND and CANL is OK, but after I connect CANH from SN65HVD to V2C bridge, the screen turns off (doesnt even matter if that ESP is powered ON or not). I defined HW version 14 in config.h of WIFIdisplay, CTX pin is connected to D5, CRX to D4, CANH from SN65 to CAN on V2C bridge and pin 9 on screen, CAN L to CAN L on V2C and pin 7 on screen. Upraveno 23. květen 2020 uživatelem VojtouNerCZ Citovat
morcibacsi Odesláno 23. květen 2020 Odesláno 23. květen 2020 Nice to hear that at least half of it started to work I just checked a VAN-CAN Bridge and the WifiDisplayControl and it seems like it is working fine together. I have a 1.4 version (bridge) and an 1.1 version (WifiDisplay). I tested outside the car, but that shouldn't affect anything. If you have HW version 14 then CTX pin should be D15 and CRX should be D18 (unless you have a different setup) CAN H is pin 9 on display and CAN L is pin 7 GND is on pin 3 at the display. I have created an Y cable for the 2 V2C bridge: Citovat
VojtouNerCZ Odesláno 23. květen 2020 Autor Odesláno 23. květen 2020 I really dont know what is going on -_- Everything is connected correctly, I just tried connection only with GND, CANL and CANH connected (CRX/CTX was disconnected from arduino) and still the same. Screen connector is OK, V2C is OK, no short between cables. Citovat
morcibacsi Odesláno 23. květen 2020 Odesláno 23. květen 2020 Are the two boards are working as standalone? I mean have you checked if you only connect the PSAWifiDisplayControl does it work? Did you installed the CAN termination resistors to the boards? (R3, R4 on v1.4 and R1,R2 on v1.1 - I haven't added those to my boards) Isn't it possible that the CAN transceivers are faulty? (I had a few which didn't work at all, however it didn't have this problem as you, it just haven't sent anything to the wires) Citovat
VojtouNerCZ Odesláno 23. květen 2020 Autor Odesláno 23. květen 2020 Standalone they are working fine. V2C without any problem, wifi without any problem, I can even open the web app. I did not installed those resistors (R3 and R4). Are those necessary? I tried multiple transceivers, I got plenty of them. Citovat
morcibacsi Odesláno 23. květen 2020 Odesláno 23. květen 2020 This is a very weird error. The CAN lines should be terminated on their ends with 120 ohm resistors. It worths a shot to add them. If it doesn't help you can remove them anyways. Citovat
VojtouNerCZ Odesláno 23. květen 2020 Autor Odesláno 23. květen 2020 (upraveno) Strange thing is, that even after the screen goes black, WIFI point is still working. Gonna order those resistors. In addition, if I had a mistake in the cabling into the car, V2C and display, it probably wouldn't work at all. Upraveno 23. květen 2020 uživatelem VojtouNerCZ Citovat
VojtouNerCZ Odesláno 23. květen 2020 Autor Odesláno 23. květen 2020 (upraveno) This is how i connected everything together (of course between V2C and WIFI I got connector so I can unplug it). It is the same schematic like you have, only difference is that I don´t need quadlock in my car because aftermarket radio, so I moved everything on the ISO connector. Upraveno 23. květen 2020 uživatelem VojtouNerCZ Citovat
morcibacsi Odesláno 24. květen 2020 Odesláno 24. květen 2020 This seems fine. Just a stupid idea, isn't it possible that the CAN-H and CAN-L is switched around in one of the boards ? Just guessing, I really don't have any clue what seems to be the problem Citovat
VojtouNerCZ Odesláno 24. květen 2020 Autor Odesláno 24. květen 2020 I just double checked all my wiring. Everything looks fine according to the schematic. Gona try device outside of the car. Maybe I´ll find something. And I gonna try another CAN transceivers. Then those resistors after they arrive. Citovat
VojtouNerCZ Odesláno 24. květen 2020 Autor Odesláno 24. květen 2020 (upraveno) So I builded another one WIFI board with a new transceiver and still same. If i connect both CANL and CANH, the screen goes off. Tomorrow I´ll try to find some resistors in work and solder them. But I starting to think that those transceivers are faulty... Because that problem appears even If I dont have arduino connected to the WIFI board... Upraveno 24. květen 2020 uživatelem VojtouNerCZ Citovat
VojtouNerCZ Odesláno 25. květen 2020 Autor Odesláno 25. květen 2020 (upraveno) So... Where should I start? XD After soldering those resistors (R3, R4) and plugging it to the car, something went wrong. Screen is not working, car could start but I think I am gonna start from the zero and I'll build another V2C bridge. Upraveno 25. květen 2020 uživatelem VojtouNerCZ Citovat
morcibacsi Odesláno 25. květen 2020 Odesláno 25. květen 2020 If you remove R3 then it'll go back to normal. R4 should be enough for the CAN part. Soon I'll start working on an Android app which will have the same functionality as the WifiDisplayControl but this time via a bluetooth connection. So if it isn't that urgent for you then you can also wait for that. Citovat
VojtouNerCZ Odesláno 8. červen 2020 Autor Odesláno 8. červen 2020 I finally have some time to try it with R3 removed and latest firmware, same problem. So I think I will wait for that app Citovat
VojtouNerCZ Odesláno 16. srpen 2020 Autor Odesláno 16. srpen 2020 (upraveno) So, after some time I got bored, so I tried latest versions of V2C and wifi display, If there is any change or possible fix to my problem after connecting WIFI board. Sadly, it´s still same. But I found one mistake, that I didnt faced before. Because I have auto lights (I am not actually using sensor on front glass, but after startup my lights turn on without touching lever), the screen flickers between low and high brightness, as you can see on video MOV_1780.mp4 Upraveno 16. srpen 2020 uživatelem VojtouNerCZ Citovat
morcibacsi Odesláno 17. srpen 2020 Odesláno 17. srpen 2020 That is an interesting issue you have there... Currently the screen brightness is tied to the dashboard lighting which should be turned on when the automatic light is on. I just tested this on my car, and if I turn on the automatic headlight by pressing the button on the left stalk it will light up the dashboard as well. Previously the dimming was connected to either the low beam or the high beam, but another user reported that it does not follow the A/C lighting mechanism so I changed it. I'll se what I can do about this... so everybody will be satisfied. Regarding the Wifi I don't have much news for you. I can't reproduce it so there is not much I can do about that. However as I said before I am working on an Android application which communicates with the V2C on bluetooth. I am new to Android development so the progress on the app isn't lighting fast.... but I have an early version of it (you can call it as a pre-alpha :D). I am testing it in my car to see if the modification causes any issues on the existing functionality. Currently I am busy on real life stuff (renovating our house), but next week I try to upload the changes needed for the Android app, and I upload the app here so you can thinker with it. In the meanwhile can you upload some VAN captures for me? The best would be to have 2 captures: one with the auto lighting enabled (when the screen flickers) and one with disabled, so I can compare what is the difference. Citovat
VojtouNerCZ Odesláno 22. srpen 2020 Autor Odesláno 22. srpen 2020 Although I have a light sensor on my car, I don't use it (yet, it is deactivated via diagnostics), but I have set the lights to turn on automatically via diagnostics. I will then send the data. But I found an interesting thing. We bought a second 307 (1.6 petrol automatic), and the converter with the WIFI module runs as it should. So it looks like my car doesn't like something. Maybe some other type of BSI, I don't know. Nevermind. I still have plans with android radio, so I don't mind Citovat
VojtouNerCZ Odesláno 13. únor 2021 Autor Odesláno 13. únor 2021 (upraveno) After a long time, I returned to the converter because I have nothing to do while I am in quarantine. I bought an RD4 radio, which will only be used to set the time and date. However, I'm kind of fooled by the controls, the values are set as they please and the display still flashes. Where can be the mistake? Oh, my bad, just find out where the problem is https://github.com/morcibacsi/PSAVanCanBridge/issues/12 VID_20210213_123322(0).mp4 Upraveno 13. únor 2021 uživatelem VojtouNerCZ Citovat
VojtouNerCZ Odesláno 1. březen 2021 Autor Odesláno 1. březen 2021 Hello @morcibacsi I want to try on my china android head unit this project you did. But I got some problems with compiling, as you can see on screenshot bellow. Dont you know why? I tried moving files between directories, but it just wont work Citovat
morcibacsi Odesláno 1. březen 2021 Odesláno 1. březen 2021 As I can see you haven't installed it as an Arduino library (C:\Users\YOUR_NAME\Documents\Arduino\libraries\) It can work like this as well just try replacing: #include <JunsunPSAVANRemote.h> with #include "JunsunPSAVANRemote.h" (<> --> "") VojtouNerCZ a Péťa ohodnotil 2 Citovat
