TomasARN Odesláno 20. duben 2018 Odesláno 20. duben 2018 Potreboval by som radu. Prestalo fungovat stropne LED osvetlenie, predne aj zadne a kozmeticke zrkadla. Vylucovacou metodou som zistil, ze nejde do stropneho svetla kostra, lebo ak privediem napriklad do kozmetickeho zrkadla kostru, tak potom vsetko funguje. Napada vas kde by mohol byt problem? Citovat
MJSytic Odesláno 22. duben 2018 Odesláno 22. duben 2018 Nezkratuje ti to kamera/kabel/adapter od ní? Myslím, že jí máš také napájenou, tak jak jsem to dělal tehdy já, ne? Citovat
TomasARN Odesláno 22. duben 2018 Autor Odesláno 22. duben 2018 Neskratuje, zistil som, ze problem je na PIN10 zlto zeleny kabel nema kostru, ked som ju tam priviedol, islo to, tak som dnes k nemu natiahol zvlast kabel od ineho zlto zeleneho a zatial to funguje. Ked neslo osvetlenie, nesla ani kamera, proste nic, bolo to uplne mrtve. Jedine co fungovalo bol ovladac clony panoramatickej strechy Citovat
TomasARN Odesláno 25. duben 2018 Autor Odesláno 25. duben 2018 Skusal uz niekto reboot BSI ? Vraj ked je najaky problem, napriklad aj s osvetlenim, je dobre spravit reboot http://www.petercoopercarrepairs.co.uk/peugeot_bsi_reboot_procedure.htm Some of you will have already come across a strange problem when programmingkeys on 2002 onwards Bsi equipped Peugeot. This usually presentsitself as a complete instrument cluster failure after the keys havebeen programmed when the customer comes to collect the car.BSI UnitThe BSI unit is basically a computer whichhandles a multitude of functions such asodometer value, central locking, lights andimmobiliser. Some later Bsi units are liableto corrupt their own software program ifnot “woken up” in a specific way afterprogramming keys or battery disconnection.The details of this are exploredthoroughly in a Peugeot TSB but I willsummarise for you briefly.Procedure for Initialising the BSI after key learning1. Disconnect the diagnostic tool.2. Put the driver’s window down, lift the bonnet and ensure allequipment is switched off.3. Ensure all doors are closed and remove key from theignition.4. Wait for 3 minutes, disconnect the vehicle battery and wait15 seconds.5. Reconnect the vehicle battery, wait a further 10 seconds (donot open doors.)6. Switch on the side lights through the driver's window.7. Switch on the ignition and check system’s functionality.8. Hold lock button on key down for 10 seconds.9.remove key open & close door test central locking system10. Start the engine and complete the system’s check.Failure to follow this procedure could result in incorrect operation of manyBSI related items.It did take three attempts following this procedure before it worked. Citovat
