kujon106 Odesláno 3. srpen 2010 Odesláno 3. srpen 2010 Hola hej Vcelku nedávno se ke mě dostala zajímavá věcička. Už dříve z doslechu jsem slyšel, že by raceland kit přímýho sání + kvalitní filtřík měl na standardním 16V 87kW motoru přidat něco okolo 6hp. Nicméně jak píšu, bylo to víceméně z doslechu typu \"jedna paní povídala\". No a pak sem narazil na následující povídání. Převzato odsud. Překládat to nebudu, kdo nehoví angličtině nechť užije google translate. Jen vypíchnu \"nejzajímavější\" poznatky. Hi, Had a rolling road day at Alan Jeffreys in Plymouth yesterday. As ever, top notch service from them and it was a very interesting day Third time we\'ve been to these rollers in the last 18 months and they\'ve always been very consistent. Anyway, results: MK2 Polo 1.0 - K&N panel filter: 50.5Bhp Mk3 Golf VR6 - Standard: 180.2Bhp Mk2 Saxo VTS - Raceland induction kit andPowerflow cat back: 133.2Bhp 106 GTi - Raceland induction kit: 138.1Bhp 106 Rallye - 1.6 bottom end, PH2 Newmans cam, Raceland manifold, sports cat, Magnex cat back and R1 bike carbs: 108Bhp (was waaaaaay overfuelling. Made 121Bhp previously with same mods but without the carbs) Now with my car I did a back-to-back test with a Raceland induction kit and then the OEM setup with a K&N panel filter. MK2 VTS - Raceland induction kit, Raceland manifold, Magnex de-cat and Magnex cat back: 132.1Bhp @ 6500Rpm and 121lb/ft @ 4500Rpm Red line is standard airbox with K&N. Blue line is with Raceland Induction Kit and red filter. With K&N panel filter: 127.6Bhp @ 6400Rpm and 118lb/ft @ 3500Rpm Very interesting to say the least. 5.5Bhp gain from fitting a Raceland Induction Kit Bearing in mind last time I went to these rollers I got 124.7Bhp but car needed a service, exhaust was blowing and filter was shagged. Friends DC5 only made 202Bhp on these rollers too so I don\'t believe they over-read. Cannot get my head round the standard GTi! Makes no sense. Either way, they\'re only numbers and probably should be taken with a pinch of salt but 5.5Bhp from a Raceland induction kit, yes please! Citovat
pp205 Odesláno 3. srpen 2010 Odesláno 3. srpen 2010 otevreny karbecy = mazec ps_: spotreba o 100% :-) u T16 o 52 koni ale 40/100 nebyl problem .... Citovat
mattoni1425 Odesláno 4. srpen 2010 Odesláno 4. srpen 2010 já teda nevím ale pokud k tomu neupravíš i zbytek tak ti jen filtr poníky nepřidá... Citovat
kujon106 Odesláno 4. srpen 2010 Autor Odesláno 4. srpen 2010 No tak podle grafu z brzdy, kterej je výš, přidá Citovat
mattoni1425 Odesláno 4. srpen 2010 Odesláno 4. srpen 2010 ale z grafu neni videt zdali nema jeste nejaky upravy.... Citovat
kujon106 Odesláno 5. srpen 2010 Autor Odesláno 5. srpen 2010 Z grafu ne, ale z textu okolo ano Citovat
kattas Odesláno 5. srpen 2010 Odesláno 5. srpen 2010 asi tak nejak...samozrejme musis met ten filtr delany na miru tvemu autu,pokud ho tam jen tak nejak zbuhdarma bouchnes,nemusi to vzdy byt ku prospechu veci...najlepsi je koupit sportovni vlozku do tveho filtrboxu,tam neni co posrat...anebo zainvestovat a koupit filtrbox novy od k&n...kazdopadne pri koupi obyc sport.filtru,kde to napojis bud primo na klapku,anebo nekam vyvedes nemas nikdy jistotu toho,ze tam nebude prilis horky vzduch z motoru... Citovat
kujon106 Odesláno 5. srpen 2010 Autor Odesláno 5. srpen 2010 No a to se zas obloukem dostáváme na začátek, neb Raceland induction kitem je myšleno samozřejmě toto: Citovat
mattoni1425 Odesláno 5. srpen 2010 Odesláno 5. srpen 2010 jelikož anglicky moc nerozumím, beru že toto: Magnex de-cat and Magnex cat back, bude něco o výfuku protože nic jinýho jako exhaust tam nevidím. jinak já mám K&N filtr, kterej je delanej prímo na tu jednotku ze sem oddelal veskerej plast od vzduchu a dal to tam primo, je to dle navodu, ale nejak mi neprijde ze bych mel lepsi vykon. ale nemuzu videt rozdil treba mezi 60 konmi a 62 konmi to chapu.ale zvuk to ma hezkej coz jsem moc rad. taky me ten filtr vysel na 2,5k a jinak ted vymyslim jak to odstínit od motoru a dovest k tomu nejak vzduch ale asi jsem uz neco vymyslel tak uvidim jaka bude realizace. Citovat
mattoni1425 Odesláno 5. srpen 2010 Odesláno 5. srpen 2010 jj tohle to znam ale kdyz vy máte jinak privedenej vzduch nez já už v serii. Původně zaslal: kujon106 No a to se zas obloukem dostáváme na začátek, neb Raceland induction kitem je myšleno samozřejmě toto: [upravil dne 4/1/2011 17:09 Béďa] Citovat
kujon106 Odesláno 5. srpen 2010 Autor Odesláno 5. srpen 2010 Tohle sání pasuje i na 1.1, resp. viděl sem je, krom 1.5D, na všech motorech 106 mk2. Anglicky nemusíš umět, stačí si přeložit v google translate toto: Very interesting to say the least. 5.5Bhp gain from fitting a Raceland Induction Kit Cannot get my head round the standard GTi! Makes no sense. Either way, they\'re only numbers and probably should be taken with a pinch of salt but 5.5Bhp from a Raceland induction kit, yes please! Citovat
kattas Odesláno 5. srpen 2010 Odesláno 5. srpen 2010 jako ten raceland sem samozrejme myslel tim filtrboxem primo delanym na urcity vuz...proste ze je to nachystane presne tam,kde to ma byt a kde to ma dobry prisun vzduchu a je to izolovane od motoru... Citovat
mattoni1425 Odesláno 5. srpen 2010 Odesláno 5. srpen 2010 no ale pro muj vuz se tenhle box proste nedela.pro muj typ sání já mám takovou tu placku nahore a velkou skatuly dolu za motor a kolem motoru se to vraci zas zpet nahoru prostenevim proc to neudelali vsude stejny. snad to uvidite dle tohoto obrazku. sice to moc videt neni asi pujdu vyfotit do auta... Citovat
kujon106 Odesláno 5. srpen 2010 Autor Odesláno 5. srpen 2010 Máš tohle, ne? Tak tam to taky naroubuješ, né že né. A nebo totok: Citovat
mattoni1425 Odesláno 5. srpen 2010 Odesláno 5. srpen 2010 to je pravda nandal bych to tam ale vem si tu ztratu nez ten vzduch celym tim potrubim projde, na tom druhym obrazku uz je prave ta jina priruba a jde to pak primo. v tom prvnim pripade si myslim ze to bude mit max zvukovy efekt ale ne vykonovej. kdyz si predstavis ze tam neni ta placata plastova priruba ale hned filtr pridelanej na jednotce tak tak to mam ja Citovat
kujon106 Odesláno 5. srpen 2010 Autor Odesláno 5. srpen 2010 Ten vzduch jde napřímo (namísto toho aby šel x baňkama a potrubím), proto se to taky jmenuje PŘÍMÉ sání No a věřit tomu nemusíš, to je tvoje věc. Citovat
Jeny Odesláno 5. srpen 2010 Odesláno 5. srpen 2010 kujone, ta poslední fotka nebyl zrovna dobrej příklad, když už je to vícebodý vstřikování, leda že by jsi myslel, že má předělat komplet sání jinak, díky grafu se už snad konečně rozhoupu a taky to raceland sání objednam:mad: [upravil dne 5/8/10 Jeny] Citovat
mattoni1425 Odesláno 5. srpen 2010 Odesláno 5. srpen 2010 já to chápu že je to přímé sání že to právě že neprochází několika baňkama, ale na te prvni fotce to právěě přes tu rozpěrnou tyč pořádně není vidět jesli tu baňku má vyndanou nebo jí tam má stále danou. baňka po původním filtru a před ní dát ten kit raceland by bylo zbytečné ne? Citovat
