Jacobsoon Odesláno 26. duben 2010 Autor Odesláno 26. duben 2010 Původně zaslal: tommas11 Burton Men’s T-6 Snowboard Whether you seek remote French steeps via helicopter or rip expert-only lines and secret stashes at your favorite local resort, few freeride snowboards give you the same level of exceptional performance found on Burton’s T6 snowboard. In fact, this is one of the feature-laden freeride snowboards you’ll find on the mountain this season. We always liked the shock-absorbing cushion offered by the T6 for big air fanatics, but this season Burton made the padding a little more earth friendly with Eco EVA padding material made from recycled materials. The even-profile T-6 has always been one of Burton’s most responsive boards, topping their “feel” rating system in terms of performance, so this season Burton upped the response and adjusted the maximum values in their “feel” scores to accommodate this model. Burton also added their new Channel binding mount system that allows riders to customize their binding stance while improving the connection between their bindings and their snowboards for improved power transmission. The Channel is compatible with Burton 3D and EST bindings, so you can modify your binding stance width or angle to match your riding style. To keep this design light and durable, Burton used their proven Alumafly Core, a tip-to-tail honeycombed aluminum core that adds up to 90% air when you do the structural math. The advantage to using this core over organic wood cores is that the T6 core features a consistent snap and response that lasts for many seasons. This Alumafly Core is also wrapped in a Triax Response fiberglass for versatile all-mountain flex and response. The Burton T6 remains paired with Burton’s Sintered N20 WFO Base, the fastest Burton base that won’t demand extra care and performance waxes at the end of every snow day. The Sintered N20 WFO Base has a dual temperature wax impregnation process that holds wax better than previous base formulas. Burton also consulted Pininfarina, the Italian designers who do work for Ferrari, Maserati and Jaguar to create this season’s T6 graphic design. We like the bold simplicity of the contrast colors on all of the T6 boards. Another nice touch is the extended size range in the T6 collection. If you’re a larger guy and you’re put off by the limited pop potential of boards created for riders in lighter weights, the T-6 features larger lengths with better weight capacity for more riders. Az si to prectes tak zjistiz ze zakladna prkna je burton a pininfarina dodelal jen graficky desing(obraz) nikoly tvar.. tvar je stejny jako na jinych modelech jen je tenhle ve specialni edici..:papa neplet si pojmy s dojmy a pokud nesneses kritiku nedavej bludy a domenky na forum.. vzdyt sem ti tam napsal ze pf delal jen design, tvar a slozeni prkna je jina vec.. tvar a slozeni desky se odviji podle ucelu pouziti a stylu jizdy.. jednalo se mi o to vetsi logo ve kterem je ta sipka (znacek burtonu, muzes ho videt na alu a na volantu..) mimo jine si me nekritizoval nybrz opravoval. Citovat
Jacobsoon Odesláno 26. květen 2010 Autor Odesláno 26. květen 2010 [upravil dne 26/5/10 Jacobsoon] Citovat
Jacobsoon Odesláno 12. květen 2011 Autor Odesláno 12. květen 2011 [upravil dne 7/7/11 21:28 Jacobsoon] [upravil dne 12/7/11 22:36 Jacobsoon] [upravil dne 26/7/11 od Jacobsoon] [upravil dne 8/8/11 od Jacobsoon] [upravil dne 11/10/11 20:56 od Jacobsoon] [upravil dne 17/10/11 19:09 od Jacobsoon] [upravil dne 20/10/11 12:34 od Jacobsoon] [upravil dne 22/10/11 15:11 od Jacobsoon] Citovat
chechet Odesláno 14. květen 2011 Odesláno 14. květen 2011 pekne p*co, pekne! nevim proc mas 2 vlakna, ale odstraneni dvd prehravace byl dobry krok. jeste ti tam trci nejaka tlacitka z ridicovych dveri. kazdopadne krasne a elegantni cabrio pro 4 lidi a presne tak to ma byt. kam se hrabou dnesni CC nesmysly. Citovat
Mišak 306 Odesláno 14. květen 2011 Odesláno 14. květen 2011 No až na ten volant a pedály krásné auto..:-) Citovat
Creams Odesláno 14. květen 2011 Odesláno 14. květen 2011 Krásné jen ten volant a pedaly tam moc nesedí , ale to tady již někdo zmínil. Nestalo by za hřích vyleštit čelní plochy kol ) [upravil dne 14.5.2011 16:35 Creams] Citovat
