razdvatri Posted March 24, 2013 Share Posted March 24, 2013 caute, dnes sa mi asi na sekundu pocas jazdy 90km/h rozsvietila, citil som akoby prestal zaberat motor, pustil som plyn, potom islo vsetko normalne dalsich 100km jazdy sa nic nestalo. Co s tym mohlo byt? inac vsetko slape ok. motor 1.1 ... je nutne ist do servisu? alebo to v pohode pocka este zo tri mesiace kym pojdem menit olej a potom dam v servise sa im kuknut na to. alebo to bolo len nejaky miniskrat? Quote Link to comment Share on other sites More sharing options...
bezdo Posted March 24, 2013 Share Posted March 24, 2013 vydrzi,... Az kym sa nepokazi. Pre tieto pripady odporucam tu tak velmi zatracovanu cinsku obd diagnostiku,ktoru staci napichnut do konektoru, BT sa spoji s hocijakym mobilom s androidom,do ktoreho stiahnes program torque a mas jednoduchu diag.v mobile. Takto skontrulujes mini chyby a vazne si das nacitat origo PP2000 v servise. Hlavne tam nemusis chodit s miniskratom. Quote Link to comment Share on other sites More sharing options...
Vulgi.svk_BA Posted March 24, 2013 Share Posted March 24, 2013 nehodis nejaky link na tu cinu na ebay? je nejaka app aj na ios? alebo funguje to aj na pc? Quote Link to comment Share on other sites More sharing options...
bezdo Posted March 25, 2013 Share Posted March 25, 2013 odb2 s BT- napr TU a program do PC napr. scan master elm, dokonca som teraz na googli nasiel aj scan master elm pre android. Ako je to s inymi operacnymi systemami neviem, treba hladat navod som dal. Quote Link to comment Share on other sites More sharing options...
razdvatri Posted March 25, 2013 Author Share Posted March 25, 2013 ale tak pytam sa normalne, ci to moze byt aj nieco mega vazne, alebo len nejaky mini skrat, este som postrehol, niekedy mi prestane napriklad blikat smerovka, ci uz na jednu stranu alebo na druhu... Quote Link to comment Share on other sites More sharing options...
razdvatri Posted March 26, 2013 Author Share Posted March 26, 2013 motor piska, ked je chladny? dnes som ho mal chvilu na volnobeh pusteny a trochu piskal, potom prestal, Quote Link to comment Share on other sites More sharing options...
