hondes Posted March 21, 2013 Share Posted March 21, 2013 Zdravim. Dneska som si namontoval led denne svietenie vsetko mam napojene tak ako to ma byt len som zistil ze +12 voltov ktore dostanem po otoceny kluca aby som napajal led tak mi pri zosliapnuti brzdoveho pedalu prestanu svietit....neviete preco to tak je? Quote Link to comment Share on other sites More sharing options...
Ferry Posted March 21, 2013 Share Posted March 21, 2013 nevime, pac netusime, na jake draty jsi to zapojil ani netusime, jake auto mas (rocnik vyroby) Quote Link to comment Share on other sites More sharing options...
hondes Posted March 21, 2013 Author Share Posted March 21, 2013 rocnik 1997...tak dal som dole kryt z poistiek co su pod kapotou a jednoducho som meral s meracim pristrojom kde sa nachadza +12v po otoceni klucom...nasiel som asi 3 a potom som zistil ze kazdy pri sliapnuti na brzdy sa potom 12v strati.. [upravil dne 21/3/13 20:16 od Ferry] Quote Link to comment Share on other sites More sharing options...
Ferry Posted March 21, 2013 Share Posted March 21, 2013 najdi si na pojistkovce nejaky drat, jehoz cislo bude zacinat pismenem A (napr. A30) a pripoj se na nej Quote Link to comment Share on other sites More sharing options...
Patrius83 Posted March 23, 2013 Share Posted March 23, 2013 Tomu se rika ekonomicka jizda... Quote Link to comment Share on other sites More sharing options...
hondes Posted March 23, 2013 Author Share Posted March 23, 2013 a neviete niekto preco to takto robi s tou brzdou? nechce sa mi tahat kabel nejak von pod kapotu az Quote Link to comment Share on other sites More sharing options...
Guest servisman Posted March 23, 2013 Share Posted March 23, 2013 denní jsem nedělal ale všechny 3 dráty napojíš pod kapotou,kostra je jasná,kabel k obrysovkám taky,jen kabel napájení po startu a ten se napojí na pojistkovou skřín v prostoru motoru něco najdeš zde Quote Link to comment Share on other sites More sharing options...
hondes Posted March 23, 2013 Author Share Posted March 23, 2013 denní jsem nedělal ale všechny 3 dráty napojíš pod kapotou,kostra je jasná,kabel k obrysovkám taky,jen kabel napájení po startu a ten se napojí na pojistkovou skřín v prostoru motoru něco najdeš zde kostru mam, kabel k parkovackam tiez, a kabel na +12 po otoceni klucom na poistkovu skrinku som uz mal napojeny len som zistil ze sa mi strati šťava po zasliapnuti na brzdu Quote Link to comment Share on other sites More sharing options...
Guest servisman Posted March 23, 2013 Share Posted March 23, 2013 to jsem četl,ale nějak mi to nebere, někde je podle mne chyba,napiš na jaký kabel číslo jsi to napojil . Quote Link to comment Share on other sites More sharing options...
hondes Posted March 23, 2013 Author Share Posted March 23, 2013 to jsem četl,ale nějak mi to nebere, někde je podle mne chyba,napiš na jaký kabel číslo jsi to napojil . tak kostru som napojil za lave svetlo, tam bola skrutka ku karoserii tak tam som to napojil. http://www.ulozisko.sk/599685/2013-03-23-016.jpg Parkovacky - ten zeleny kablik http://www.ulozisko.sk/599686/2013-03-23-017.jpg A ten cervenz kabel je +12V po otocenz klucom a napojil som ho tam kde som y meracim pristrojom nasiel prud http://www.ulozisko.sk/599682/2013-03-23-018.jpg [upravil dne 23/3/13 15:32 od hondes] Quote Link to comment Share on other sites More sharing options...
Guest servisman Posted March 23, 2013 Share Posted March 23, 2013 mám rok 98 ale uplně jiné pojistky v motoru podle pojistek tipuji jiný rok než 97 co jsi napsal Tipl bych rok 99 a vejš Quote Link to comment Share on other sites More sharing options...
OK406 Posted March 23, 2013 Share Posted March 23, 2013 hondes: zde je moje zapojení, akorát tam není uvedeno zapojení na vypínač. To mi dělal servisman. Quote Link to comment Share on other sites More sharing options...
Ferry Posted March 23, 2013 Share Posted March 23, 2013 ty nas tahas za fusekli, jakej rok 1997? Ta pojistkovka, co je na obrazku je z noveho modelu 406, pri trose fantazie tam vidim datum vyroby 30/08/99, takze to je uz po faceliftu a s jednotkou BSI myslim, ze tim bastlem nekam poustis +12V, kam nemas, proto ti to zhasina, kdyz slapnes na brzdu Quote Link to comment Share on other sites More sharing options...
hondes Posted March 23, 2013 Author Share Posted March 23, 2013 nevie papierovo je to 97 mozno bol prerobeny na noovsi neviem nevyznam sa to je moj prvy peugeot.....a co myslis tym balastem tomu nechapem Quote Link to comment Share on other sites More sharing options...
Guest servisman Posted March 23, 2013 Share Posted March 23, 2013 dej VIN a napovíme co a jak Quote Link to comment Share on other sites More sharing options...
MJSytic Posted March 23, 2013 Share Posted March 23, 2013 On píše \"bastl\" a to je něco jako \"ne moc dobře udělaná věc\" Je se jen zeptám, na tom kabelu se ti ztratí napětí, i když máš to denní odpojené? Quote Link to comment Share on other sites More sharing options...
hondes Posted March 23, 2013 Author Share Posted March 23, 2013 On píše \"bastl\" a to je něco jako \"ne moc dobře udělaná věc\" Je se jen zeptám, na tom kabelu se ti ztratí napětí, i když máš to denní odpojené? niesom som si isty ale asi tam ten prud bol...zajtra zistim a aj to VIN napisem Quote Link to comment Share on other sites More sharing options...
Guest servisman Posted March 23, 2013 Share Posted March 23, 2013 to nemáš u sebe malej techničák ? to jsem zvědav co zjistíme Quote Link to comment Share on other sites More sharing options...
hondes Posted March 23, 2013 Author Share Posted March 23, 2013 VIN VF38BRHYF80920255 Quote Link to comment Share on other sites More sharing options...
ChouLu Posted March 23, 2013 Share Posted March 23, 2013 Počátek záruky 26.11.1999 Dle DAM vyrobeno 6. Září 1999 Quote Link to comment Share on other sites More sharing options...
