Dark69 Posted March 17, 2013 Share Posted March 17, 2013 Zdraviim... Pri zapnuti zapalovania mi nesvieti kontrolka oleja, kontrolka baterie svieti. Neviete mi poradit ako rozobrat tu pristrojovu dosku??? Chcel by som vymenit ziarovku kontrolky a nenasiel som tu ziadny navod. Mam 2.0 HDI 79Kw R.v. 05/2003 Dakkujeem Quote Link to comment Share on other sites More sharing options...
ChouLu Posted March 17, 2013 Share Posted March 17, 2013 Olej svítit nemá... a v přístrojovce jsou SMD LED diody;) Quote Link to comment Share on other sites More sharing options...
sauromalus Posted March 17, 2013 Share Posted March 17, 2013 Mně svítí obě,olej i dobíjení, do nastartování. Jsou li tam žárovky nebo LED, nevím Mám 307 break z roku 2/2005. 1,4/16V. Jinak další viz: Quote Link to comment Share on other sites More sharing options...
Dark69 Posted March 17, 2013 Author Share Posted March 17, 2013 Zatial stojim na mrtvom bode Kontrolka oleja a baterky musi svietit...Baterka mi svieti po zapnuti zapalovania do 2.polohy a olej nie...Takze bude vypalena ziarovka...Ledky ze vraj maju az novsie 307-cky po facelite, a nemaju uz kontrolku oleja ani baterie. Je to pod hlaskou STOP.. Preto som napisal hore aj rok mojej 307-cky... A v tom vlakne co si mi poslal, nieje nic ohladom demontaze pristrojovky ale aj tak dik... [upravil dne 17/3/13 19:26 od Dark69] [upravil dne 17/3/13 19:28 od Dark69] Quote Link to comment Share on other sites More sharing options...
shark734 Posted March 17, 2013 Share Posted March 17, 2013 LEDky su aj v starsom modeli, mam 2ks 307 a ani v jednej nieje kontrolka mazania.... Quote Link to comment Share on other sites More sharing options...
Dark69 Posted March 17, 2013 Author Share Posted March 17, 2013 A kontrolku baterie mas?? LEn kontrolku oleja nie ako ja?? Teraz uz mam riadny chaoss Quote Link to comment Share on other sites More sharing options...
sauromalus Posted March 17, 2013 Share Posted March 17, 2013 Tak, pokud jde o demontáž přístrojovky, tak dle \" jak na to\" se použije dvou trnů zasunutých do otvorů v dolní části přístrojovky, tím dojde k vycvaknutí západek a přístrojovku lze vysunout . ( Tolik teoreticky ) Jinak bych ještě prověřil tlakový spínač oleje, tedy jeho činnost zkusil simulovat odpojením kablíku a posléze jeho zkratováním na kostru (v 2. poloze klíčku). Tedy pokud se tak již nestalo. Quote Link to comment Share on other sites More sharing options...
shark734 Posted March 17, 2013 Share Posted March 17, 2013 Dark69: kontrolku baterky mam...a to mazanie maju asi len benzinaky:myslim Quote Link to comment Share on other sites More sharing options...
307rg Posted March 17, 2013 Share Posted March 17, 2013 ľudia, dokedy chcete toto riešiť, už tu bolo o tom napísané úplne všetko, kto má 307čky by už mal mal vedieť, že každý kus môže byť iný takže by ma neprekvapili ani žiarovky aj keď ja osobne som sa ešte s takou prístrojovkou nestretol......podstatné je, že každý diel má minimálne dvoch dodávateľov a tým to je, pekne to je vidieť napr. na páčkach keď jeden návod na opravu vôbec nemusí sedieť práve na tie moje...(ani v peugeote servise sa s vami nebudú bez čísla VIN baviť, na základe modelu alebo roku výroby vám nič neobjednajú) kto sa bojí, nech si spraví skúšku s odpojeným konektorom od snímača tlaku oleja prepojeným s kostrou, samozrejme za chodu motora a treba chviľku počkať, reakcia nie je okamžitá...ale vlastne aj o tom sa už tu písalo... Quote Link to comment Share on other sites More sharing options...
307rg Posted March 17, 2013 Share Posted March 17, 2013 ...a mám benzín a mazanie mi tiež nesvieti pred štartom, nezáleží na tom, či je to benzín alebo nafta Quote Link to comment Share on other sites More sharing options...
Dark69 Posted March 17, 2013 Author Share Posted March 17, 2013 Vdaka za rady Stresoval som, lebo ta kontrolka oleja mi nesvieti na palubovke, a po zapnuti klucika mi ukaze len na displeji hladinu oleja. Lenze raz mi blika ze olej je na minime a druhykrat ze hladina oleja je plna... Tak nikdy neviem comu mam verit pred jazdou a nechce sa mi stale teraz kontrolovat rucne olej. p.s a kde najdem to cidlo tlaku oleja? A potom len konektor prilozim o blok motora? Ako ked na skodovke sa skusa sviecka o blok motora ci iskri?? [upravil dne 17/3/13 20:48 od Dark69] Quote Link to comment Share on other sites More sharing options...
sauromalus Posted March 17, 2013 Share Posted March 17, 2013 Jo. Jen se obávám, že k tomu budeš potřebovat kousek drátu. Čidlo by mělo reagovat na tlak oleje v mazací soustavě, co měří výšku hladiny, netuším. Ale taky mi to trochu kecá, hladina byla mezi min a max a display hlásil jedna čárka chybí. Ale vzhledem ke spotřebě oleje nemusím zatím mezi intervaly výměny ( cca 20000km) dolévat, hladina klesne k min, tak mě to nepálí. Quote Link to comment Share on other sites More sharing options...
307rg Posted March 18, 2013 Share Posted March 18, 2013 čidlo tlaku oleja je na mojom motore priamo pod olejovým filtrom, ako je to u HDI presne neviem ale určite ho nájdeš, samozrejme konektor je v izolácii tak najjednoduchšie bude použiť kúsok drôtu výšku hladiny sníma tiež nejaký snímač (predpokladám, že je niekde vnútri motora) a nie je nič neobvykle keď neukazuje presne, hlavne u starších áut, asi to ovplyvňuje zanášanie nečistotami a usadeninami a samozrejme auto musí stáť vodorovne...jeho funkcia je iba orientačná, v prípade reklamácie pri poruche motora je podstatný skutočný stav podľa mierky oleja, nie ten čo sa zobrazuje na displeji Quote Link to comment Share on other sites More sharing options...
Dark69 Posted March 18, 2013 Author Share Posted March 18, 2013 Vdaka za rady, tak budem skumat auto cez vikend Quote Link to comment Share on other sites More sharing options...
zolco Posted January 6, 2016 Share Posted January 6, 2016 Chcel by som vymeniť osvetlenie palubovky ledkami.Kolko lediek tam ide?Aký typ žiaroviek tam je?Vie to niekto prosím?Ďakujem! Quote Link to comment Share on other sites More sharing options...
Roman Bazi Posted January 6, 2016 Share Posted January 6, 2016 (edited) Pomůže Ti tohle? Jsem na mobilu, a nedaří se mi to sem vložit jako odkaz. www.peugeot-club.com/index.php?/topic/48746-změna-podsvětlení/?fromsearch=1 Edited January 6, 2016 by Roman Bazi Quote Link to comment Share on other sites More sharing options...
