Joseph1 Posted December 17, 2010 Share Posted December 17, 2010 zdravim ludia mam problem s ventilatorom a v historii som nenasiel nic konkretne ............... takze vcera som zapol ventilator a nic tak som sa pustil do hladania problemu ale poistka je ok a nikam inam som sa nedostal ........ viete mi niekto poradit ako ho vymontujem ???? pripadne nejaky navod s foto alebo co to moze byt???? ide hlavne o to ze ked skusam ho zapnut na max. tak tam len nieco cvakne........... dik za rady Quote Link to comment Share on other sites More sharing options...
Qcko Posted December 17, 2010 Share Posted December 17, 2010 Toto je problem s elektronikou priamo na ventilatore, elektrikari ti aj povedia ako sa to vola presne, ventilator je pod spolujazdcovymi nohami, riadna supa, neprehliadnes;) Quote Link to comment Share on other sites More sharing options...
Joseph1 Posted December 17, 2010 Author Share Posted December 17, 2010 zdravim takze ventilator uz odstavil auto (( dnes ked som ho nastartoval tak sa ventilator spustil s tym ze sa rozsvietilo dobijanie a nedosiel som ani z prace domov a ostal som visiet na dialnici v DE....... kde moze byt problem ?????? alternator je po celkovej GO pred 2000km ........ Quote Link to comment Share on other sites More sharing options...
paric Posted December 17, 2010 Share Posted December 17, 2010 Hm, tak ked svietilo dobijanie, tak zeby alternator, alebo nejaky skrat na kabloch ? Inak nefunkcny ventilator som riesil tu ale obavam sa ze tvoj problem to asi nebude lebo to neodstavi cele auto. Quote Link to comment Share on other sites More sharing options...
Joseph1 Posted December 17, 2010 Author Share Posted December 17, 2010 netusim kde moze byt problem som v DE v praci a hlavne ma sere to ze altik som daval robit komplet takze som s takou vecou neratal ani vo sne a moje vbavenie tvori skusacka hviezdicove kluce a plochy a krizovy srobovak ....... staci mi dat nejaku radu alebo zachytny bod.....nikomu sa nieco podobne nestalo??? Quote Link to comment Share on other sites More sharing options...
comm Posted December 17, 2010 Share Posted December 17, 2010 netusime ani aky mas agregat!! inak zmeral by som napetie na baterke. neviem ci si skusal nastartovat auto je dost mozne ze prebijala baterka alebo nedobijala prva varianta je ta najhorsia. Inak ak to nenastartujes nabit baterku alebo kupit novu a nechat skontrolovat altik ale taku moznost mat asi nebudes tak ze by som doporucoval nabit samozrejme skontrolovat v mot.priestore poistky a nastartovat. Tu neviem prene aky typ motora mas bo su jednotky ktore niesu schopne vydrzat napetie vysie ako 17V ak ty rebijal az moc je to v ....... . Je tu vela moznosti tazko sa radi. premerat kontrola poistiek nabytie(kupa) baterky Quote Link to comment Share on other sites More sharing options...
Joseph1 Posted December 18, 2010 Author Share Posted December 18, 2010 mam 1.8 16V old model takze poistky su ok bateriu nabijam zajtra premeriam.......skusal som nahodit druhu bateriu a pri zapnuti ventilatora ten ventilator stiahol komplet celu elektriku Quote Link to comment Share on other sites More sharing options...
P607Olda Posted December 18, 2010 Share Posted December 18, 2010 Auto normálne ide, dobíja, len ventilátor hnevá? Vyber ventilátor a skús odpojiť (preskočiť) elektronickú reguláciu. Urob to núdzovo tak, že natiahneš +12 V od baterky alebo od zapaľovača (neviem, či má zapaľovač dosť silnú poistku). Napatie priveď rovno na motor ventilátora (elektronickú reguláciu odpoj!) a ako predradný odpor daj žiarovku 55W, teda čo ide do hlavných svetiel. Vtedy sa bude točiť na polovičné otáčky a možeš jazdiť. Na fotky pozri to vlákno, čo píše paric. [upravil dne 18.12.2010 12:41 P607Olda] Quote Link to comment Share on other sites More sharing options...
Joseph1 Posted December 18, 2010 Author Share Posted December 18, 2010 takze ventilator nesiel na druhy den po praci sa spustil s tym ze hned na to sa rozsvietilo dobijanie apresiel som 13 km v kolone a zostal som stat....... dnas som kupil nabijacku a nabijam baterku kupil som aj multimeter tak zajtra sa dam do toho ak to neporiesim tak zacnem hladat nejaky servis Quote Link to comment Share on other sites More sharing options...
P607Olda Posted December 18, 2010 Share Posted December 18, 2010 Odpoj vadný ventilátor, aby neskratoval. Zmeraj napatie na baterke pri naštartovanom motore, musí byť vyše 14 V. Vtedy je nabíjanie OK. Potom vyber ventilátor, nájdi elektroniku na ňom a odpoj ju. Skús motor, či sa ľahko točí, či nie je zadretý. Samotný motor skús pripojiť na baterku - buďto rovno, alebo lepšie cez rezervnú žiarovku hlavných svetiel. Pozor, motor sa pritom veľmi cukne, vrtula sa roztočí, aj to zaiskrí, tak nech ti to nevypadne z ruky. Ak by to takto fungovalo, tak to sprevádzkuj s tou žiarovkou - možeš tak jazdiť aj pol roka. Quote Link to comment Share on other sites More sharing options...
Joseph1 Posted December 19, 2010 Author Share Posted December 19, 2010 vytiahol som ventilator ale nemam ho ako skusit kedze mam obmedzene prostriedky a kabel nemam odkial zobrat ....... skusal som ho zatocit a urobi jednu otocku tak neviem ci je zadrety .......auto som nastartoval dobijanie svieti a po zmerani som zistil ze stale nedobija ....poistky su ok Quote Link to comment Share on other sites More sharing options...
