pascall007 Posted December 16, 2010 Share Posted December 16, 2010 Zdravim.... mate niejake skusenosti s montazou kde to vsetko napchat aby to vyzeralo good ?popripade niejake foto vdaka Quote Link to comment Share on other sites More sharing options...
stefano Posted December 17, 2010 Share Posted December 17, 2010 Treba len hľadať. Quote Link to comment Share on other sites More sharing options...
Pe.Tr Posted December 17, 2010 Share Posted December 17, 2010 to je 3200 a to je uplne jina jak 9200 , každopadně nezapomen se před montáží vybavit redukci , cca 1300,- na www.stualarm.cz Quote Link to comment Share on other sites More sharing options...
stefano Posted December 17, 2010 Share Posted December 17, 2010 Otázka bola na montáž a umiestenie, tak preto odkaz na toto video. Na tejto stránke sú odkazy aj na 9200-ku. Quote Link to comment Share on other sites More sharing options...
pascall007 Posted December 17, 2010 Author Share Posted December 17, 2010 redukciu uz mam stala 10£ diky moc zajtra to skusim namontovat Quote Link to comment Share on other sites More sharing options...
pascall007 Posted December 18, 2010 Author Share Posted December 18, 2010 tak po prvom pokuse som to vzdal ked som vybral vsetky tie kable tak som zistil ze nieje kde to tam strcit asi sa musi rozobrat pol palubovky Quote Link to comment Share on other sites More sharing options...
jofo Posted December 18, 2010 Share Posted December 18, 2010 Ale co. Za hornym displejom je miesta dost. Quote Link to comment Share on other sites More sharing options...
pascall007 Posted December 18, 2010 Author Share Posted December 18, 2010 nj je tam dost muselo ist vsetko von radio,dysplay,popolnik,ovladanie kurenia ale ide to perfektne Quote Link to comment Share on other sites More sharing options...
Brizan Posted December 18, 2010 Share Posted December 18, 2010 to je 3200 a to je uplne jina jak 9200 , každopadně nezapomen se před montáží vybavit redukci , cca 1300,- na www.stualarm.cz A kterou redukci máš přesně na mysli? Taky uvažuji o HF sadě a zjištuji co je vše potřeba. Díky Quote Link to comment Share on other sites More sharing options...
pascall007 Posted December 19, 2010 Author Share Posted December 19, 2010 to je 3200 a to je uplne jina jak 9200 , každopadně nezapomen se před montáží vybavit redukci , cca 1300,- na www.stualarm.cz A kterou redukci máš přesně na mysli? Taky uvažuji o HF sadě a zjištuji co je vše potřeba. Díky mne trebalo tutu PC000016AA na ebay ju mas lacno na parrot stranke sa da zistit aku redukciu potrebujes http://www.parrot.com/uk/support/installationdiagrams mne funguje vsetko ako ma som uplne spokojny s mki9200 Quote Link to comment Share on other sites More sharing options...
Jurko Posted January 4, 2011 Share Posted January 4, 2011 Můžeš sem dát prosím foto,jak to máš namontované?Jinak redukci jsem našel tady http://www.audiocar.cz/detail-handsfree-parrot-bluetooth-parrot-redukce-peugeot,-citroen,-fiat-86165-181.html Quote Link to comment Share on other sites More sharing options...
Stepkao Posted January 6, 2011 Share Posted January 6, 2011 Ahoj, nevíš jestli je stejná redukce u CK3100? Chci si koupit MKi, tak jestli ji musím shánět.. Nemáte někdo fotky postupu upevnění mikrofonu, nebo jak všechno demontovat? Quote Link to comment Share on other sites More sharing options...
Marcel00 Posted January 6, 2011 Share Posted January 6, 2011 neviem co ten parrot stoji, predpokladam ze okolo 180~200e a predpokladam ze mas radio rd4, ale neoplati sa za tu cenu toho vsetkeho nahodit origo Bluetooth modul ? je to integrovane do vozidla, v podstate origo, info z mobilu na displayi PP, nic neni na palubovke dodatocne monotovane (osobne mi to vadi). Len sa pytam tak ma hned neukamenujte Quote Link to comment Share on other sites More sharing options...
Stepkao Posted January 7, 2011 Share Posted January 7, 2011 koupíš ho za cca 150e a sám mám vyzkoušené že parrot podporuje mnohem víc telefonů. Co mám CK3100, tak ho chci měnit jen kvůli telefonu s androidem, kterej už nezvládá.. Většina výrobců aut má horší HF než když si ho přikoupíš, ale na druhou stránku taky nemám rád když je v autě něco navíc, ale už tam jedno mám, tak ho jen vyměním za hezčí kousek:) a navíc rd4 nemám... Quote Link to comment Share on other sites More sharing options...
Laďa Posted January 7, 2011 Share Posted January 7, 2011 Když nemáš RD4 tak proč řešíš parrot? Quote Link to comment Share on other sites More sharing options...
Stepkao Posted January 7, 2011 Share Posted January 7, 2011 Sorry. chtěl jsem napsat RT Quote Link to comment Share on other sites More sharing options...
pascall007 Posted January 7, 2011 Author Share Posted January 7, 2011 mna parrot vysiel na 100£ vsetky kable+skrinku,adapter som ulozil za odkladaci priestor pri spolujazdcovi takze musela ist cela skrinka von plus stredovy panel (radio,display ovladanie klimy) trvalo to asi vsetko 1hod, kable na ipod,usb mam natiahnute do popolnika (ale rozmyslam ze ich prehodim do odkladacej skrinky) microfon mam upevneny za volantom.Z parratom som uplne spokojny aj co sa tyka hudby.mal som pochybnosti ci ho zparujem s iphone ale vsetko ide ako ma zajtra nahodim foto Quote Link to comment Share on other sites More sharing options...
Stepkao Posted January 7, 2011 Share Posted January 7, 2011 Nějaký problém u zapojení jsi neměl? Musí se při zapojování v určitou chvili zapnout klíček, nebo tak něco, u některých aut se to musí... Já mám mikrofon nad stínítkem, tak dufám že až ho budu tahat nově, tak to dám podle něj, snad to půjde.... Quote Link to comment Share on other sites More sharing options...
pascall007 Posted January 8, 2011 Author Share Posted January 8, 2011 nemal som ziaden problem pri zapojeni. Quote Link to comment Share on other sites More sharing options...
pascall007 Posted January 8, 2011 Author Share Posted January 8, 2011 Quote Link to comment Share on other sites More sharing options...
