Existujuci Posted December 11, 2010 Share Posted December 11, 2010 Da sa Windows 7 /64 bit zmenit na 32 bit ? Quote Link to comment Share on other sites More sharing options...
Qcko Posted December 11, 2010 Share Posted December 11, 2010 Nie ... ...iba preinstalovat Quote Link to comment Share on other sites More sharing options...
FrantaCV Posted December 11, 2010 Share Posted December 11, 2010 K čemu by to bylo dobré??? Quote Link to comment Share on other sites More sharing options...
Existujuci Posted December 11, 2010 Author Share Posted December 11, 2010 Pri instalacii jednaj hry mi vyskocilo okno s touto otazkou. Moznost bola len OK a instalacia sa vypla. W 7 je na tuto hru asi priliš. Quote Link to comment Share on other sites More sharing options...
MrChodny Posted December 11, 2010 Share Posted December 11, 2010 a rezim kompatibility na ten instalator nezabral? Quote Link to comment Share on other sites More sharing options...
Dadadavid Posted December 11, 2010 Share Posted December 11, 2010 No to je jedina nevyhoda 64-bit systemu-kompabilita..ja jsem vyzkousel visty jak 32 tak 64,windows 7 to same a stejne jsem se pres vsechno vratil k xp,vsechno ostatni znatelne zpomaluje pc,treba na windows 7 mi nesly skoro gta 4... jinak samozrejme zmenit jdou pomoci preinstalovani ... Quote Link to comment Share on other sites More sharing options...
Existujuci Posted December 11, 2010 Author Share Posted December 11, 2010 a rezim kompatibility na ten instalator nezabral? Neviem ako sa to robi? Vies poradit? Quote Link to comment Share on other sites More sharing options...
MrChodny Posted December 11, 2010 Share Posted December 11, 2010 pravym tlacitkem na instalator (vetsinou setup.exe), vybrat Vlastnosti a tam zalozku Kompatibilita a vybrat treba Windows XP. Quote Link to comment Share on other sites More sharing options...
Existujuci Posted December 11, 2010 Author Share Posted December 11, 2010 pravym tlacitkem na instalator (vetsinou setup.exe), vybrat Vlastnosti a tam zalozku Kompatibilita a vybrat treba Windows XP. Diki idem skusit Nepomohlo to-skoda. kua serem na taky comp. ked tu nic z XP nejde. [upravil dne 11/12/10 22:44 Existujuci] Quote Link to comment Share on other sites More sharing options...
straki007 Posted December 11, 2010 Share Posted December 11, 2010 A jakou hru instalujes??? Mam Wokno 7 64bit a vse naprosto v pohode. Od NFS shift az po COD Black ops.. Quote Link to comment Share on other sites More sharing options...
Pata Posted December 11, 2010 Share Posted December 11, 2010 Dadadavid: to chce mít nejdřív pořádné železo, v práci mi ta 4G paměť skoro nestačí a to tam nepouštím hry Quote Link to comment Share on other sites More sharing options...
shark734 Posted December 11, 2010 Share Posted December 11, 2010 problem s kompatibilitou na win 7 64bit je jedine v starych hrach a aplikaciach....a vzdy sa to dalo nejako rozbehat Quote Link to comment Share on other sites More sharing options...
AKCZ Posted December 11, 2010 Share Posted December 11, 2010 Pres virtualizaci se da pak rozjet ledasco.. ale graficky narocnejsi hry asi blbe Win7 64bit mam sice v praci ale domu si jeste pockam.. Quote Link to comment Share on other sites More sharing options...
AnotherOne Posted December 12, 2010 Share Posted December 12, 2010 Spomínané GTA 4 vrátane GTA 4EFLC ide na W7/64 úplne spoľahlivo. Jediný problém bol nainštalovať Rockstar Game Club, ten sa odmietal inštalovať, ale po dohovore sa podvolil Prakticky som ešte nemal hru čo by nešla na W7/64 rozchodiť. Teda nejaké extra staré som neskúsal. Quote Link to comment Share on other sites More sharing options...
Chepp Posted December 12, 2010 Share Posted December 12, 2010 Takz stejny nazor.... ten kdo zustane na W.XP je proste zastaraly.... tento system chapu na starem zelezu. W7 je rychlejsi lepsi... ve vsech ohledech... tak nechapukdo se tomu brani..... umi nativne podporovat milion veci kterym se XP pred deseti lety o tom ani nezdalo.... priznam se neparim.... Ale vsechny svoje PC ntb predelelavam na w7.. vsem znamym..... vsem firmam... A zas mam vice casu... protoze uzivatel si klikne na vyresit problem... a ono ho to vyresi.... kdyz si to USB strci CAM tak se sama nainstaluje... tolik zbytecnych problemu odpadai... diky bohu. Quote Link to comment Share on other sites More sharing options...
koblih69 Posted December 12, 2010 Share Posted December 12, 2010 .............. A zas mam vice casu... protoze uzivatel si klikne na vyresit problem... a ono ho to vyresi.... kdyz si to USB strci CAM tak se sama nainstaluje... tolik zbytecnych problemu odpadai... diky bohu. To zní dobře myslím, že by se to mělo začít instalovat i do aut a domácností a postupně bych to instaloval i jinam a zřídil vzdálenej přístup. Naboural jsi? Klikneš pravým tlačítkem na ikonku bouračky a W7 problém vyřeší... Quote Link to comment Share on other sites More sharing options...
michal 307 sw Posted December 12, 2010 Share Posted December 12, 2010 ahoj:papa cose tyče windovs 7 nemate nekdo licensy nebo odkaz dik. Quote Link to comment Share on other sites More sharing options...
Existujuci Posted December 12, 2010 Author Share Posted December 12, 2010 A jakou hru instalujes??? Mam Wokno 7 64bit a vse naprosto v pohode. Od NFS shift az po COD Black ops.. Takze NTB Lenovo Intel core I3-2.4G/Windows7/ HDD-500GB/RAM-4GB/Grafika N vidia GeForce 1GB. Slusna masina, Skusal som inst.od jednoduchej hry CS-1.6:nainstalujem ju,aj otvorim,ale po vybrati mapy uz nejde dalej spustit. Farcry:nejde vobec nainstalovat. Battlefield 2-tiez nejde. NFSUG2. uz som horko tazko prisiel na to ako zmenit kompatibilitu aj som ju nainstaloval ale pri starte musim vlozit a pocas hry musi byt vlozene CD2.No a toto mi akosi nechce zobrat.Pritom z toho CD2 instalovalo druhu púolovicu hry.Tak nechapem. O nic nejde len chcem vyskusat tu grafiku a nemam na akej hre. [upravil dne 12/12/10 10:23 Existujuci] Quote Link to comment Share on other sites More sharing options...
jozefsv Posted December 12, 2010 Share Posted December 12, 2010 najdi si novsiu hru ked chces vyskusat grafiku nie tieto stare Quote Link to comment Share on other sites More sharing options...
Existujuci Posted December 12, 2010 Author Share Posted December 12, 2010 najdi si novsiu hru ked chces vyskusat grafiku nie tieto stare Nic ine doma nemam,aj to su este po synovi co kedysi hraval. NSFUG2 je uz narocnejsia na grafiku,alebo nie? Quote Link to comment Share on other sites More sharing options...
