Kocure Posted July 21, 2010 Share Posted July 21, 2010 ZDRAVIM VAS, KED NA MOJEJ 307(2004) BRZDIM Z VYSSICH RYCHLOSTI,DOCHADZA K HADZAVOSTI VOLANTU.POCAS BEZNEJ JAZDY SA TO NEOBJAVUJE IBA PRI PRUDKOM BRZDENI..MOZETE MI PROSIM PORADIT?AUTO MA CCA 92TIS A PREDNE BRZDOVE PLATNICKY UZ MENENE BOLI...(AUTO SOM KUPOVAL CCA PRED POL ROKOM AKO JAZDENE) Quote Link to comment Share on other sites More sharing options...
AnotherOne Posted July 21, 2010 Share Posted July 21, 2010 Môžu to byť krivé kotúče. Quote Link to comment Share on other sites More sharing options...
Ferry Posted July 21, 2010 Share Posted July 21, 2010 prosim, pis bez CAPS LOCK, jinak priste mazu bez varovani. O hazeni prednich kotoucu u 307 je spoustu cteni v sekci 307, zkus tam pohledat jak uz bylo napsano, mohou to byt krive kotouce ( mohou byt obrouseny pod minimalni tloustku), mohou byt krive naboje, spatna loziska kol ( ty pak mohou zpusobovat dalsi zvlneni kotoucu, takze i kdyz das kotouc novy, po case se zvlni zas a zase bude kopat) chce to zmerit uchylkomerem maximalni hazivost kotouce a pak i samotneho naboje, u obou by nemela presahnout 0.05mm [upravil dne 21/7/10 Ferry] Quote Link to comment Share on other sites More sharing options...
