MHS Posted July 17, 2010 Share Posted July 17, 2010 mel sem problem s prepinacem COM, byla pretrhnuta paska, tuto chybu uz sem odstranil novym tim strednim krouzkem,vse funguje ale chyba zustala svitit,dá se to nejak smazat?nebo mela zmizet sama? Nechce se mi zbytecne na diagnostiku kdyby to slo smazat nejak manualne diky za nazory Quote Link to comment Share on other sites More sharing options...
Guest SB Posted July 17, 2010 Share Posted July 17, 2010 Skus na chvíľku odpojiť baterku , malo by to pomôcť Quote Link to comment Share on other sites More sharing options...
MHS Posted July 17, 2010 Author Share Posted July 17, 2010 baterku sem mel dlouho odpojenou jak sem tam daval ten prepinac a airbag,ale zkusim to znovu Quote Link to comment Share on other sites More sharing options...
MHS Posted July 17, 2010 Author Share Posted July 17, 2010 tak kontolka porad sviti.. [upravil dne 17/7/10 MHS] Quote Link to comment Share on other sites More sharing options...
Guest SB Posted July 17, 2010 Share Posted July 17, 2010 tak to musí na diagnostiku - tá určí chybu, často je chybou konektor pod predným sedadlom vodiča alebo spolujazdca. skus ich vyčistiť Quote Link to comment Share on other sites More sharing options...
MHS Posted July 17, 2010 Author Share Posted July 17, 2010 myslis?ja mel chybu bagu ve volantu mel sem problem s COM paskou,vymnenil sem novy dil a kontrolka porad sviti,zkusim jeste ty konektory jak rikas Quote Link to comment Share on other sites More sharing options...
MHS Posted July 20, 2010 Author Share Posted July 20, 2010 konektory sou pod sedackou v poradku,ale píše mi plubni PC ted chybu A bag Belts Faulty takze to chapu ze by to melo byt neco s pasy,,, koukal sm pod kryt a v oranzovych kablicich k pasu jsou odpory. Je tato hlaska k pasum nebo se pletu?v cim by mohla byt chyba? Quote Link to comment Share on other sites More sharing options...
shark734 Posted July 20, 2010 Share Posted July 20, 2010 mal si nejaku buracku? alebo si to tak uz kupil? ja som riesil nieco podobne a cez dia som zistil ze som mal trvalu zavadu odpalenia pyropasov a bolo treba raktivovat RJ airbagov a pri oprave som si vsimol ze ked otocis kluc do 2.polohy pred nastartovanim tak pri trvalej zavade(pred reaktivaciou RJ) kontrolka AIRBAGU svieti...po reaktivacii RJ v 2. polohe kluca zhasla a pri nastartovani sa rozsvietila znova(to bola prechodna zavada-odpojeny konektor pod sedackou)..po zapojeni kontrolka zhasla Quote Link to comment Share on other sites More sharing options...
MHS Posted July 20, 2010 Author Share Posted July 20, 2010 Bouračku sem nemel,auto uz sem tak koupil:( Jak sem auto kupoval zadna kontrolka nesvitila. Zacla svitit po pul roce zjistil sem ze mam v háji COM pasku Tu sem nedavno vymnenil, ale kontrolka sviti porad. Takze hledam kde by mohla byt chyba. Takze budu muset reaktivovat ŘJ bagu? nebo ten odpor co tam je je spatny? Kontrolka svítí neustale tzn. pred nastartovani o po nastartovani Quote Link to comment Share on other sites More sharing options...
shark734 Posted July 20, 2010 Share Posted July 20, 2010 nemusi to byt trvala zavada...moze byt ze na novsich rocnikoch je to inak...skus tam dat nove odpory 2,2ohmove a naspajkuj ich napevno...ked nepomoze tak uz jedine dia:nevim Quote Link to comment Share on other sites More sharing options...
MHS Posted July 20, 2010 Author Share Posted July 20, 2010 dival sem se ti blazni to meli omotane el cernou pasku ,,ten odpor tam je nastrceny da se rict navolno skusim stim neco udelat,snad to pomuze jinak koupim bud nove pyropasy nebo odpory:bojim:grr Quote Link to comment Share on other sites More sharing options...
shark734 Posted July 20, 2010 Share Posted July 20, 2010 nejde mi do hlavy preco tam mas odpory ked to nebolo burane..inak ja som sa na pyropasy vykaslal ajtak sa zasekavaju tak ze mam problem si zobrat okuliare z palubky za jazdy Quote Link to comment Share on other sites More sharing options...
MHS Posted July 20, 2010 Author Share Posted July 20, 2010 no bourane mnou nebylo ale nekde ve Francii beztak ano, podle me ty h.... takhle skryli,asi tam nakonec fakt dam nove odpory... Quote Link to comment Share on other sites More sharing options...
MHS Posted July 21, 2010 Author Share Posted July 21, 2010 Nemá nekdo schema neo neví nekdo jaky kabel vede k pyropasum,ktery k bocnim bagum ,a stropnim bagum? CHci se podivat na ty odpory a newim ktery vede k čemu, CHyu mi to hlasi k pasum tak nechci se spllest a napaet to jinam Quote Link to comment Share on other sites More sharing options...
shark734 Posted July 21, 2010 Share Posted July 21, 2010 kable od pyropasov idu priamo do RJ airbagov co je pod stredovym tunelom, v miestach pod radiacou pakou-tie kable su oranzove kable k sedackovym bagom idu tiez do RJ a pod kazdou sedackou je modry konektor-ja som ho mal tiez rozpojeny a nechapem ako, lebo kable maju rezervu:myslim no a hlavove som este neriesil ale pravdepodobne to bude tak isto len kable asi pojdu cez stlpik B [upravil dne 21/7/10 shark734] Quote Link to comment Share on other sites More sharing options...
MHS Posted July 21, 2010 Author Share Posted July 21, 2010 takze kabel pyropasum je u radici paky?takze bych mel rozebrat cely ten tunel nebo jen kryt od radicky, Jeste me zajima jak poznam pyropatronu a kde ji najdu? Je u navijaku pasu nebo u zapinani pasu? Quote Link to comment Share on other sites More sharing options...
shark734 Posted July 21, 2010 Share Posted July 21, 2010 jj kabel vedie od RJ bagov, pod palubku a potom dalej v prahoch...a musis zlozit cely stredovy tunel-je to tak max na 15 minut...a patrona je pri navyjakoch, pozri si toto je tam fotka: Quote Link to comment Share on other sites More sharing options...
MHS Posted July 21, 2010 Author Share Posted July 21, 2010 takze kdyz to zhrnem.. Kablik od pyropasu je na tom navijaku(ted je spis vedle toho navijaku ve kterem mam nacpany odpor) Cely ten oranzovy kablik vede od navjaku pres stredni tunel az Ř bagu. Takze bud bude nekde obvod preruseny nebo je ten odpor K.O Podle hlasky palubni PC , A Bag Belts Faulty by to mely byt pyropasy, Radsi jeste jednou skontroluju konetory pod sedackou a podobne. Pokud nenajdu chybu a bude vse OK je možne že kdyz sem vymnenil COM pasku ze budu muset resetnou RJ bagu Quote Link to comment Share on other sites More sharing options...
shark734 Posted July 21, 2010 Share Posted July 21, 2010 tie kable od pyropasov sa nemaju kde prerusit, ak neboli \"nadpajane\"...a vymena pasky nemoze sposobit trvalu zavadu, skus tam vymenit tie odpory a ak to nepomoze tak chod na dia..bez nej je to nadlho:nevim Quote Link to comment Share on other sites More sharing options...
MHS Posted July 21, 2010 Author Share Posted July 21, 2010 takze to budou asi odpory no dobre zkusim to projit a kdyz tak diu zatim dík Quote Link to comment Share on other sites More sharing options...
