cvrlo 25 Posted December 11, 2020 Share Posted December 11, 2020 zdravím, dnes mi na diagnostike ukázalo aktívnu chybu U1218, viete mi niekto povedať, čo to znamená. Auto ide bez problémov. Dík. Quote Link to post Share on other sites
ferinko2 449 Posted December 11, 2020 Share Posted December 11, 2020 Toto ti asi nepomôže U1218 This fault maybe interpretted by the BSI faults log as a Cruise control system data fault, related to the injection system. This maybe due to data faults on the network, caused by software anomalies from, either one of the display units, or the BSI. cvrlo 1 Quote Link to post Share on other sites
cvrlo 25 Posted December 11, 2020 Author Share Posted December 11, 2020 no neviem, je to dosť všeobecné... Quote Link to post Share on other sites
HonzaZ 637 Posted December 11, 2020 Share Posted December 11, 2020 U1218 - obecně závada komunikace mezi BSI a ostatními počítači. Pokud chceš opravdu zjistit o co jde a jestli vůbec nějaká závada existuje, musíš použít pro dia origo Diagbox a ne nějakou univerzální dia. cvrlo 1 Quote Link to post Share on other sites
cvrlo 25 Posted December 11, 2020 Author Share Posted December 11, 2020 no to asi áno, len nikto známi autoelektrikár v okolí Lexiu nemá, závada bola diagnostikovaná na Texe a nešla vymazať (vraj vymazať môže max. 5 chýb) Quote Link to post Share on other sites
HonzaZ 637 Posted December 11, 2020 Share Posted December 11, 2020 Pokud vše funguje jak má, tak bych to neřešil Quote Link to post Share on other sites
cvrlo 25 Posted December 11, 2020 Author Share Posted December 11, 2020 na diag som išiel preto, lebo ráno pri naštartovaní mi vypísalo problém s brzdovým systémom (abs, ručná, esp), dnes ráno po naštartovaní všetko v poriadku, na diag žiadna závada okrem tohto ale ak sa to nebude opakovať, budem to riešiť tak, ako radíš . Dík Quote Link to post Share on other sites
HonzaZ 637 Posted December 11, 2020 Share Posted December 11, 2020 Quote Link to post Share on other sites
cvrlo 25 Posted December 11, 2020 Author Share Posted December 11, 2020 Quote Link to post Share on other sites
ChouLu 1,442 Posted December 11, 2020 Share Posted December 11, 2020 klasická závada pokud máš stop start, tak většinou věští horší nebo vadnou baterii, jinak neřeš cvrlo 1 Quote Link to post Share on other sites
cvrlo 25 Posted December 12, 2020 Author Share Posted December 12, 2020 štart stop našťastie nemám, batéria je nová AGM takže neriešim dík všetkým za rady Quote Link to post Share on other sites
