Peugeot 306 sedan tips and a question
Hello everyone, Recently I bought a Peugeot 306 Style Sedan 1.9D It has only 70k km on clock and it looks like brand new. It was kept inside a garage and was not driven in past few years that often because the woman was older and was not able to drive anymore. It is really a nice looking car and well kept. It was driven only from one town to the other (nearest larger one) that is like 10km away.
So my question is, Break peddal feels hard to push down, people have said to be that is becuase of corrodion because the car was not driven that often, corrodion on the breaks, and that will come off, could that be the reason? I saw that there is a bit of corrodion on them.
https://19216811.cam https://xender.vip https://testmyspeed.onl
And steering feels a bit stiff, is that normal in these types of car?
So my main concern are the breaks, any help would be thankful.
Edited by NicholasJaxson
If there is hard to push feeling on pedal when break, it can be lack of vacuum feed to brake booster rather then corrosion of brake disc. So maybe leak on tubes or bad vacuum pump, which is mounted on the right side of the engine on camshaft.
For the steering, is the car equipped with power steering system? If yes, check the fluid level
  • 1 year later...
