kukikuk Posted February 15, 2016 Share Posted February 15, 2016 Potreboval bych poradit, kde najdu snimac vlhkosti v kabine u této 407. Pise me to na diagnostice chybu: F702-zavada snimace vlhkosti v kabine. Není charakterizovana. Mistni. Quote Link to comment Share on other sites More sharing options...
Přema Posted February 15, 2016 Share Posted February 15, 2016 před spolujezdcem .... ty 3 drážky v okrasné liště Quote Link to comment Share on other sites More sharing options...
kukikuk Posted February 15, 2016 Author Share Posted February 15, 2016 A myslis, ze to roseni oken ovlivnilo to cidlo? Je na nem klimatizace hodne zavisla? Quote Link to comment Share on other sites More sharing options...
Přema Posted February 15, 2016 Share Posted February 15, 2016 A jak se ti to mlžilo....jen v dešti nebo pořád......? Quote Link to comment Share on other sites More sharing options...
kukikuk Posted February 16, 2016 Author Share Posted February 16, 2016 Zjistil jsem, ze vůbec nesepne klima když je venku zima a ja dam klimu na minimum. To asi ovlivnuje to cidlo vlhkosti? Poti se to porad když nesepne klima asi. Quote Link to comment Share on other sites More sharing options...
Přema Posted February 16, 2016 Share Posted February 16, 2016 spíš mrkni jestli jede ventilátor na chladiči...... dej na dia jeho test...... věř tomu že nepojede..... Quote Link to comment Share on other sites More sharing options...
Laďa Posted February 16, 2016 Share Posted February 16, 2016 Když je venku zima, tak dej klimu na maximum. Quote Link to comment Share on other sites More sharing options...
kukikuk Posted February 16, 2016 Author Share Posted February 16, 2016 To vim, ze ten ventilator u chladicu dost často odchazi, ale muze to ovlivnit to ze se potej okna? Ten ventilator ma vliv na klimatizaci a hlavne když je venku teplo není to tak? Urcite ten ventilator otestuju ale. Ted v zime nesepne, ale na diag to odzkousim. Quote Link to comment Share on other sites More sharing options...
Přema Posted February 16, 2016 Share Posted February 16, 2016 bez funkčního ventilátoru nesepne klima a klima vysušuje vzduch Quote Link to comment Share on other sites More sharing options...
foxo Posted February 16, 2016 Share Posted February 16, 2016 (edited) mam uplne ten isty problem. Stale zamlzene okna, Dia. ukazala spatne cidlo vlhkosti v kabine, a tez mam pocit, ze nesepne klima. Mam v plane to v blizkej dobe vymenit. A snad je to tym... Premku: jak skontroluju ten ventilator cez DiagBox? Je to tam v sexci "kliimatizace"? (abych vedel, kam se podivat bez nejakeho dlheho hledani) Edited February 16, 2016 by foxo Quote Link to comment Share on other sites More sharing options...
Přema Posted February 16, 2016 Share Posted February 16, 2016 Nemenit zadne cidlo vlhkosti v kabine.....to je dobre i kdyz pise chybu.... problem je na 99% ve ventilatoru..... verte mi osobni zkusenost Odesláno z mého SM-G928F pomocí Tapatalk Quote Link to comment Share on other sites More sharing options...
Přema Posted February 16, 2016 Share Posted February 16, 2016 Diag box nepouzivam..... i kdyz ho mam.....na 407 staci bohate PP2000 Odesláno z mého SM-G928F pomocí Tapatalk Quote Link to comment Share on other sites More sharing options...
kukikuk Posted February 16, 2016 Author Share Posted February 16, 2016 To je ale divne, ze me klima občas sepne a občas ne. Pokud by byl spatnej ventilator, tak klima nesepne nikdy není to tak? Quote Link to comment Share on other sites More sharing options...
foxo Posted February 16, 2016 Share Posted February 16, 2016 (edited) no ja mam iba ten DiagBox, a tam je PP2000 oklestena na vozy, co jdou cez DiabBox... A nemam ani NTB s winXP, abych mohl dat solo program PP2000 A ked ho nejakym zazrakem skontrolujem cez dia, a zistim ze nejde, kde byva pricina? Zhoraty motor, prepalene draty, spatne rele... Co treba menit? Edited February 16, 2016 by foxo Quote Link to comment Share on other sites More sharing options...
kukikuk Posted February 17, 2016 Author Share Posted February 17, 2016 Vetsinou zatece voda do RJ toho ventilatoru a zoxiduje cely ten plosnak. Quote Link to comment Share on other sites More sharing options...
kukikuk Posted February 17, 2016 Author Share Posted February 17, 2016 Tak ventilator funguje. Sice me nejde odzkoušet na diagnostice-když dam test, tak se neroztoci coz nechapu proc, ale při sepnuti klimy se zacne tocit. Quote Link to comment Share on other sites More sharing options...
foxo Posted February 17, 2016 Share Posted February 17, 2016 ta RJ ventilatoru je nekde pri nem? Quote Link to comment Share on other sites More sharing options...
kukikuk Posted February 18, 2016 Author Share Posted February 18, 2016 ano Quote Link to comment Share on other sites More sharing options...
kukikuk Posted February 19, 2016 Author Share Posted February 19, 2016 Cidlo vlhkosti vymeneno z jiného auta a chybu haze stále, ventilator funguje, ofukovani celniho okna také-vzduch tam proudi, tak me reknete cim to ještě muze byt? Uz si nevim rady. Quote Link to comment Share on other sites More sharing options...
HonzaZ Posted February 19, 2016 Share Posted February 19, 2016 Io čidlo z jiného auta je v pořádku? Tato čidla totiž dost odcházejí Quote Link to comment Share on other sites More sharing options...
